Wed, Feb 26, 7:47 PM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2025 Feb 23 2:34 pm)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: File Distribution Help Please
Andarianedomon ( ) posted Sat, 10 January 2004 at 11:21 AM · edited Thu, 30 January 2025 at 11:32 PM
  1. Installed Daz modelor a .zip file(doesn't matter specific model any model will do)to programfiles>metacrations>Poser>Runtime 2. go into poser 3. look for item 4 not there 5. close poser 6. have to go into windows explorer 7. have to spend 10 to 20 minutes finding all the related items and trying to figure out where everything goes. HELPPpp any ideas I have used corection reference and yes it has helped on 1200 items but there still are about 850 items it could not reference. Still the main problem is the initial install.
xantor ( ) posted Sun, 11 January 2004 at 3:56 AM
If you look in zip at the path if there is nothing there then the things wont be installed in the proper place, the things have been saved without path info. you should extract to poser NOT the runtime folder then the files should all be in the right place.
EnglishBob ( ) posted Mon, 12 January 2004 at 5:48 AM
Attached Link: http://www.morphography.uk.vu/fileguide_1.html
Here's my file placement guide, should help you to sort out what's what.
