Subject: Texture query...Maybe a dumb question but.....
Deal opened this issue on Aug 31, 2000 ยท 5 posts
Deal posted Thu, 31 August 2000 at 5:57 PM
Can you apply a texture map AND a relection map at the same time and still see both the texture and the relection?
bloodsong posted Thu, 31 August 2000 at 6:02 PM
heyas; yes, deal. look.... way waaaaaaaaaaaay way back for the irridescence test i did. the peacock has it's colour texture, and a reflection map on it.
Deal posted Thu, 31 August 2000 at 6:33 PM
are there special settings?
maclean posted Thu, 31 August 2000 at 8:14 PM
yup, shore can! you can even apply a texture map as a reflection map if you want. or vice-versa. settings are whatever turns you on, I guess. if in dount, try it and see! I'm about to post a collection of maps and a mini-tutorial in the next day or two, but meantime you might want to look at the image I posted of reflection and bump maps a couple of posts down. gives you the idea. maclean
bloodsong posted Fri, 01 September 2000 at 6:06 PM
heyas; i think the reflection map can overpower the texture map if you do/don't check the multiply through texture/multiply through lights. play with those settings, you should be able to figure it out in a bit. :)
