Vethril opened this issue on Aug 31, 2000 ยท 4 posts
Vethril posted Thu, 31 August 2000 at 8:18 PM
Attached Link: And Zygote makes gives us another reason to pull our hair out! =P
shadownet posted Thu, 31 August 2000 at 8:42 PM
Lady V, looking good! Maybe some more work around the eyes and eyebrows. Also, thanks for the MobuisMillie version you posted. Just downloaded, but have not played with it. Never quite warmed up to Vickie but may start now. Rob
Mason posted Thu, 31 August 2000 at 9:17 PM
One thing might be to blotch up the skin a bit. A pass with a photoshop spray dither and a blur can add some cool skin tones that make her look more real. Also, a better texture for the lips might work well too. First ime I've seen Vicki implemented this way. Good job.
Jaager posted Fri, 01 September 2000 at 1:05 AM
Consider using the transMaps for the lashes and Upperbrows. With your P4 figure, you used an expression morph to define the arched brows. You may consider doing a morph on the upperbrows to acheive this, if you have not already. If you are a convert to ditching the brows all together, and using only the Upperbrows, I don't know if you need bother with morphing the brow mesh or not. I would try just the Upperbrows first to see.
