bonestructure opened this issue on Jan 12, 2004 ยท 9 posts
bonestructure posted Mon, 12 January 2004 at 2:45 PM
With movie film, there's a process called bleaching. It's used to desaturate the colors, but it also boosts the black and white and silver of the image. It's used to create cold or dramatic effects, and is sometimes tinted to increase the effect. I'd like to try to get this effect in Photoshop. In film, this is done by actually bleaching the film during processing. I've tried desaturating, but it doesn't look right. I've also tried placing a grayscaled version of the image under the color image and fading the opacity of the color image, but it still doesn't look like what I'm looking for. And I have no idea how to get the silvering effect. Any ideas?
TREKDEN posted Mon, 12 January 2004 at 5:18 PM
perhaps add multiple layers each with different tones of grey and then desaturate until you get that look you lookign for. Work with multiple colors and opacities, you may find the look your searching for. Just a thought.
aprilgem posted Mon, 12 January 2004 at 11:10 PM
Could you maybe post a before and after of a film version of what you're talking about? The terms make no sense to me, but I'm pretty good at guessing or discovering new Photoshop techniques if I see a before and after shot.
bonestructure posted Mon, 12 January 2004 at 11:29 PM
well, I don't have any way to do screenshots, but bleaching is used in a LOT of movies. FEAR DOT COM used it extensively, DREAMCATCHER used it a bit. It makes the picture look almost monotone at times, though it's in color. I can get the bleached out color, I just can't seem to boost the blacks and whites to the right level, and I have no idea how to get the silvery, monotone effect.
aprilgem posted Mon, 12 January 2004 at 11:54 PM
Still not sure what look you're going for, but if you want to make your blacks blacker and your whites whiter, use the Levels feature by bringing the outer triangles closer to the middle triangle. Or use the Curves feature by making an S-curve to increase the contrast between highlight and shadow. To get a really good grayscale, I'd suggest using the Lightness channel in the LAB color mode. FWIW, I hope that helps.
Hoofdcommissaris posted Tue, 13 January 2004 at 3:32 AM
ImaMayaIdiot posted Tue, 13 January 2004 at 9:25 PM
bonestructure posted Tue, 13 January 2004 at 10:25 PM
That's not bad actually. With a black and white image underneath it with the blacks and whites boosted, it might work.
billyputty posted Wed, 21 January 2004 at 9:06 PM
I am not a veteran photoshop user but I think if you research how to use calculations and blend channel info you have greater control over boosting your tones in your final image. My source for this thinking comes from a book entitled Photoshop Channel Chops by David Biedny, Bert Monroy, and Nathan Moody. New Riders publishing 1998.
