Subject: was WIP......now lost......Please Help
raptordude opened this issue on Jan 12, 2004 ยท 8 posts
raptordude posted Mon, 12 January 2004 at 9:04 PM
I was working on this....saved it three times...almost finished but now I cant load any of them. Poser goes into la-la land. Even when trying to load the pz3 file. I think its the hair and all the morphs for mike that is causing the trouble. Can the cr2 file be hacked to get rid of the morphs and hair????? But I guess I could always just start over.....ya right Thanks in advance for any help you can give me
raptordude
PheonixRising posted Mon, 12 January 2004 at 9:08 PM
try making a copy of your .pz3. Rename it to .cr2 and put it in your figure libarary. See if it will load then
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
raptordude posted Mon, 12 January 2004 at 9:24 PM
Thanks Pheonix... I'm off to try that now. I sure hope it works Thanks again raptordude
raptordude posted Mon, 12 January 2004 at 10:10 PM
Welllll not lost any more. I did copy the pz3 and change it to cr2 and it did load........in 9 minutes. Without the back ground it loaded in 6 minutes. Without the hair and background it loads in 30 sec. I had been watching Poser and when it was "not responding" I closed it down. This time I watched the task monitor and Poser was indeed running (it said it was not) but the mem use rate was slowly going up. When it got to 117,000kb the cpu use rate went to 0 and Poser was finished. Guess the bottom line is "just wait for it to finish" Thanks again for the help raptordude
PheonixRising posted Mon, 12 January 2004 at 10:48 PM
if you close poser and restart it sometimes works faster once all the little things are cleared out of memory.
xantor posted Tue, 13 January 2004 at 12:42 AM
I didn`t know that you could load a pz3 as a cr2, now, that is interesting.
n0s4ra2 posted Tue, 13 January 2004 at 6:27 AM
I personally like the morphs. I hope you keep them in.:)=
raptordude posted Tue, 13 January 2004 at 5:01 PM
Now I'm going to keep all the morphs. Just installed another hd and this one only has poser 5 on it. Funny thing...a fresh install with sr3 is only about 500mb far cry from the 6gb on my other hd..heheheh On this drive I'm only going to load in what I'm working on at the time so it will stay nice and clean and fast (ya right)Wish me luck. So many ideas and soooo little time. raptordude
