vilters opened this issue on Jan 14, 2004 ยท 13 posts
vilters posted Wed, 14 January 2004 at 3:32 PM
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Lawndart posted Wed, 14 January 2004 at 3:35 PM
Now THAT is cool!
TygerCub posted Wed, 14 January 2004 at 3:40 PM
I second the coolness factor! If you can produce that much exaggeration at the ankles and wrists for the edge of the clothes, why not the same amount for wrinkles? Do you think that is possible? I'd also be interested in seeing your displacement map to get an idea of the shading you used to get the different levels.
vilters posted Wed, 14 January 2004 at 3:51 PM
Dev
"Do not drive
vilters posted Wed, 14 January 2004 at 3:54 PM
This way U can use the P4-Lo figures as clothed background figures. And they don't eat resources. The previous post explains the procedure. happy testing, Tony
Dev
"Do not drive
TygerCub posted Wed, 14 January 2004 at 3:59 PM
Wow! Thanks!
stewer posted Wed, 14 January 2004 at 4:06 PM
Attached Link: http://www.hdm-stuttgart.de/%7Esw19/files/dron_firefly_hi.AVI
You can use stronger bump maps to create helmets or shoulderpads, and it looks great when used with matching color maps.vilters posted Wed, 14 January 2004 at 4:37 PM
That is corect stewer but .. A displacement map displaces the geometry and a bump map only gives the visual idea without actually displacing something. A displacement map even makes shadows that enhance the image. Look at the collars or the belt. You get real displacement, not only the illusion of.. even on this P4-Lo figure. It still needs further testing, but gloves, boots, bra's, panties, seem to be good canidates. And no conforming problems, even in extreme poses. See you all, it's bedtime overhere now.(Belgium) Next on the try list is a bra. Get the displacement with a displacement map, and the texture with a bump map. Could be interesting.
Dev
"Do not drive
stewer posted Wed, 14 January 2004 at 4:41 PM
Woopsi. Was a typo, I meant displacements not bumps. Sorry.
DefaultGuy posted Wed, 14 January 2004 at 5:03 PM
Attached Link: http://brian.curiouslabs.com
Wow! That IS way too COOL! -Brianvilters posted Thu, 15 January 2004 at 3:36 AM
Well, ik could work, but Poser misplaces the shadows!!! The shadow and highlight sides are reversed in the rendering.
Dev
"Do not drive
Phantast posted Thu, 15 January 2004 at 10:03 AM
I've been doing this same thing with bump maps for a while, but displacment maps are better, for sure.
bip77 posted Thu, 15 January 2004 at 7:07 PM
Great! If - like vilters said - this nasty shadow bug wouldn't be, displacement maps could do great things in poser. But for slight displacements it's maybe ignorable. The clothes look very cool!
