Forum: Carrara
Subject: No object in vertex modeller
Pete_Exxtreme opened this issue on Jan 20, 2004 ยท 5 posts
Pete_Exxtreme posted Tue, 20 January 2004 at 12:52 PM
Hi Gurus, i imported (as vertex) an OBJ file created with Amapi 7.1 in my Carrara 3.03. I want to modify in Carrara part of this object. So i select the object, then clic on the model room which opens but.... Views are empty, despite that the object has all its informations displayed, as you can see in the screenshot, and the object seems to have a normal size !!!! Where's the catch ?????
Please heeeeellllppp :-)))))))))
falconperigot posted Tue, 20 January 2004 at 2:00 PM
Pull back as far as you can in the Director's Camera view. Your object may be bigger than you thought. Mark
cckens posted Tue, 20 January 2004 at 2:03 PM
Pete, The OBJ ports the object into the VM at a higher X,Y, and/or Z axis value. Pull back on the zoom for one of the axes (I'd use Left View) and try to see if you can see it then... Hold the Z key down and the ALT key to switch to ZOOM OUT. then click on the LEFT pane. Ken dork.gif
cckens posted Tue, 20 January 2004 at 2:04 PM
Pete_Exxtreme posted Tue, 20 January 2004 at 2:06 PM
YESSS !! That's it ! the object is huge and definitely located far from the default screens ! Thanks a lot ! Pete
