kits opened this issue on Jan 20, 2004 ยท 8 posts
kits posted Tue, 20 January 2004 at 4:07 PM
Hi all got a problem when I export a poser 5 character as an obj file to CS3. When I open it up the eyeball textures are gone, making the eyes appear all white. The rest of the body and the head textures are fine. This does not happen when I do the same with a poser 4 figure. and the only workaround that I have found is to remap the P5 eyeballs with a flat map and use a normal square map. Has anyone figured out how to get the poser supplied UV map to work properly. Any help at all on this would be greatly appreciated. Chris_S
todd71 posted Tue, 20 January 2004 at 4:09 PM
are they gone in the preview or when you render? thought maybe it might just be a preview issue...
kits posted Tue, 20 January 2004 at 4:17 PM
They are gone in both the preview and the render. Chris_S
Patrick_210 posted Tue, 20 January 2004 at 5:21 PM
Probably the extra glass ball they put around the eyeball. Try isolating some of the eyeball parts and checking the invisible box to see if that's the problem.
kits posted Tue, 20 January 2004 at 5:38 PM
THanks Patrick will give what you say a try Chris_S
mateo_sancarlos posted Tue, 20 January 2004 at 7:00 PM
Search further down the list here. There is a nice tutorial on P5 to Carrara. If the boss would put it in the tutorial section, it would be easier to find.
Kixum posted Tue, 20 January 2004 at 7:25 PM
Ok, I can take a hint. -Kix
-Kix
kits posted Wed, 21 January 2004 at 4:29 PM
Thanks All Patrick had the right of it. once I made the eyeball cover and the iris cover transparent there was the texture in place all the time. I'm new to CS3 and I'm a slow learner. Once again thanks Chris_S
