Curfew opened this issue on Sep 04, 2000 ยท 7 posts
Curfew posted Mon, 04 September 2000 at 1:02 PM
Quikp51 posted Mon, 04 September 2000 at 1:09 PM
Try making it from a lattice rather than a terrain.
Curfew posted Mon, 04 September 2000 at 1:17 PM
How do I do that. I thought a terrain was a lattice. Guess my newbi-ness is showin thru...:-)
DigitalArtist posted Mon, 04 September 2000 at 1:19 PM
to create a lattice, go to the create palette and click on the double sided mountain looking thing.
Curfew posted Mon, 04 September 2000 at 1:23 PM
OK... now I feel foolish.... Using a symmetrical lattice did the trick... Guess a terrain culdn't very well be transparent, could it... Many thanks...
Hawkfyr posted Mon, 04 September 2000 at 7:35 PM
Hi Curfew, A lattice is Symetrical,(whatever is done to one side reacts on the other) But a terrain is not. Be sure to make the terrain solid by selecting "Solid" from the drop menu in the terrain editor, if you want to do boolean operations with it. in case you may not know The clipping bracket is located on the right side of the canvas in the terrain editor. click and drag on it . also Alt/click on the bracket to re-set it . good luck Hope this helps Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
Curfew posted Mon, 04 September 2000 at 7:53 PM
Thans... I got it to work.... :-)
