Laver2k opened this issue on Jan 24, 2004 ยท 3 posts
Laver2k posted Sat, 24 January 2004 at 4:27 PM
Im trying to export an animation as flash. I want it to render and look like a normal rendered character but im having problems with quality. its looking like a cartoon and when i mess with the settings it changes to be a little fuzzy. I dont have an incredibly fast computer but im only trying to render short animations. Any advice?
odeathoflife posted Sat, 24 January 2004 at 4:52 PM
Yeah...don't export to flash :) Sorry I had to. The flash in poser exports as solid colours(Like a cartoon), not textures, and it is completly dependant on the underlying colour of your mesh (the colour under the texture...it is usually white)and the lights. If you want textures in your animations then you are going to have to export to render settings. Then to make that a swf file bring into flash and export from there as a swf. If you want the cartoon lines then you are going to have to set it up in the sketch editor, and expot to current sketch settings, this will enable you to use textures as well as the cartoon lines.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Laver2k posted Sat, 24 January 2004 at 5:07 PM
i guess ill have to try making lots of images and piecing them together =/. thanks =).
