sekopasa opened this issue on Jan 25, 2004 ยท 10 posts
sekopasa posted Sun, 25 January 2004 at 6:05 PM
I have computer with 64mb Nvidia Graphic Card, 512mb sdram, p4 1,7 cpu but poser 5 works very slow on my computer what would be the problem. I also use 3ds max and in that i use more complex objects but there is no proble do you have any comments for me!
SamTherapy posted Sun, 25 January 2004 at 7:29 PM
How big and/or complex are the scenes you are rendering? Are you using Firefly? I haven't even touched Firefly on my P5 yet; still using the P4 renderer. However, the consensus is that Firefly can be painfully slow.
Becco_UK posted Sun, 25 January 2004 at 8:36 PM
I use a custom built machine with a P4 2.4 and I find renders with lots of objects/lights/transparency maps(hair) to be slow. Just a Poser thing. The firefly renderer is slower, but can produce better final renders. Render complex scenes while you sleep!
sekopasa posted Mon, 26 January 2004 at 5:54 AM
my scenes are very simple, i talk about in using, it can be realy painful to rotate, when i just added a hair prop.
Smitthms posted Mon, 26 January 2004 at 6:47 AM
Hi sekopasa... what OS are you running ? Thomas Poser Coordinator
Becco_UK posted Mon, 26 January 2004 at 6:58 AM
Not likely to be the graphics card - if I remember correctly Poser uses system memory and doesn't make use of graphic card memory. Check to see if you have unnecesary background programs running at the same time as Poser. There are object tracking options in Poser - try a different setting and see if that helps.
compiler posted Mon, 26 January 2004 at 11:32 AM
It also depends on the figure you're working on : 512 Mb could be a little short if you're loading a Vicky 3 with all the morphs injected and try to pose her using full track mode.
Mason posted Mon, 26 January 2004 at 12:57 PM
sekopasa posted Mon, 26 January 2004 at 3:57 PM
Thanks for your helps, i will try to simplize my XP
Huolong posted Tue, 27 January 2004 at 9:31 AM
Biggest single reason for Poser5 to run slow is that texture files in many downloads, both free and sold, are not aligned properly with the library items they go with. Run CorrectReference, a free utility here, on all your library items. CR will optimise the linkages and identify any missing files.
Gordon
