Strixowl opened this issue on Jan 30, 2004 ยท 18 posts
Strixowl posted Fri, 30 January 2004 at 12:57 PM
For Your Info: Almo,has uploaded links for "FREE" Manniquins for ALL the UniMesh Characters (V3-M3-S3-Freak-She-Freak) & Jp Poses (for Freak, S3, SheFreak)and a tute. They can be dowloaded from the Members Only Forum at DAZ under the post titled "Freak & Steph Petite have joined the StormGaurds",scroll down a little. :-) I would supply the link,just not sure if it's kosher anymore. Make sure and get the XAcePlus Unpacker & RTEncoder also (links supplied). :D
SWAMP posted Fri, 30 January 2004 at 1:18 PM
THANKS!!! This is great. SWAMP
xantor posted Fri, 30 January 2004 at 1:46 PM
The link is kosher till the 21st february, could you supply a direct link to the downloads page as I couldn`t find it?
Barbarellany posted Fri, 30 January 2004 at 2:17 PM
This saddly again is not for the Mac. Can you switch the JPs in the bone room of PP? I guess I'm asking can you just switch the bones in Bone room and then the use morph mover to put in the morphs?
Alchmo posted Fri, 30 January 2004 at 2:21 PM
Attached Link: http://forum.daz3d.com/viewtopic.php?t=2636
Since you are keen on it, here is the link to the forum on the DAZ3D site, as it is located inside the members only forum, you would need to be logged in.about posting direct links, i hope nobody does this without my authorization, since the files are hosted on my server
if you are unable to visit the members only forum on the DAZ3D site, you can wait a bit and it will be available in the Tutorial section on the DAZ site too
sorry if this sounds harsh, yes the files are free, yes they can be used by everyone, but i don't want others to make off-site links to files on my server (bandwidth leeching is not nice) Hope you can understand
SWAMP posted Fri, 30 January 2004 at 2:27 PM
Thanks,Alchmo Very nice of you to provide this for us. Happy SWAMP
Strixowl posted Fri, 30 January 2004 at 2:44 PM
Sorry,the link I was referring to above was the DAZ link that you provided. Totally understand the bandwidth issue. We've had so much discussion in this forum on this subject I had wanted to pass the GREAT news along........ My Apologies Alchmo, if passing this info along wasn't right by you. :-)
Alchmo posted Fri, 30 January 2004 at 2:44 PM
@Barbarellany sorry as far as i can look in on it MorphManger can not be used for this, since the manikin files, just contain single body part, morph manager would just mover over the morph target for the hip area (since the single body part contained in the manikins is named hip) applying the JP settings can be doen on the Mac as well as the JP files are simple PZ2 (Pose) files that update the JP settings for the selected figure. if i do find the time, i may look in on doing a morph container that can be used with MorphManager to transfer the morph targets from the container to the clothing item
Barbarellany posted Fri, 30 January 2004 at 2:56 PM
Thank you sooooo much Alchmo. The JPs at Daz are wrapped Win only so I can't even work with them.
Alchmo posted Fri, 30 January 2004 at 2:59 PM
Strixowl, no need to appologize, no harm done i have no problem if anyone downloads the files and hosts them on his own server, you can post these links anywhere you like (you can make it available via ED2K as well) for all the Mac users, sorry that this is not usable right "out of the box" for you, as i said i'll look in on doing a "Morphcontainer" that can be used with MorphManager (or Mac equivalent) to archieve the same results, should be possible as far as i can think about it at the moment, but ths may take some time
Alchmo posted Fri, 30 January 2004 at 3:16 PM
Attached Link: http://www.soft-rabbit.com/
@Barbarellany sorry since i do not have a Mac available, you would need to use some tool like MacConverter on them you can find this tool on the site in the attached link normally it should be possible to open the zip file on the mac extract the files and use MacConverter on them to make them Mac compatible, but since i don't have a Mac i can't verify this.jade_nyc posted Fri, 30 January 2004 at 3:33 PM
Many thanks Alchmo - this is a godsend!!! lol
xantor posted Fri, 30 January 2004 at 4:30 PM
I did say I wanted a direct link to the downloads PAGE not a direct link to the downloads, alchmo.
Porthos posted Fri, 30 January 2004 at 4:40 PM
Terrific!!! Thank you muchly!!
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD
7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
Alchmo posted Fri, 30 January 2004 at 4:42 PM
Attached Link: http://forum.daz3d.com/viewtopic.php?t=2747
i never said you did, this was just to head off any possibility, hope you understand. and following the link i attached in the first reply, you will get to the thread in teh members forum, just switch to page 3 and scroll to approximately the middle of the page or use the attached link in this replyBarbarellany posted Fri, 30 January 2004 at 6:38 PM
It was the ace files I meant. Yes Mac converter works well with poser files. I still need the container though right?
xantor posted Fri, 30 January 2004 at 9:32 PM
These are great, thank you!
Alchmo posted Fri, 30 January 2004 at 10:32 PM
the ACE files could be unpacked on a Mac using MacUnAce, (free on www.winace.com) but the ACE files at the moment only contain the manikin files for work with Tailor, as i said they will not work with MorphManager i'll look in on creating the "MorphContainer" for use with MorphManager during the next days (time permitted of course) but if something like this container is possible or not, i need to make it pretty save, since the container could be used to move the original morphs to any figure, i could get into trouble with license rights, but i'll see what i can come up with (one thing for certain, the files will be encoded, probably using OBActionMover since this tool is available on the Mac too)
