Subject: Question : Editing cr2 and other files
Holli opened this issue on Jan 31, 2004 ยท 16 posts
Holli posted Sat, 31 January 2004 at 8:35 AM
While I was still using Poser 4 I could easily edit all files (such as cr2) with the windows Notpad or Editor. All files were well formated with linefeeds and easy to read. If I create these files with P5 they are completly messed up and I am unable to read or edit anything Is there any way to bring these files in the old formated form or is there a special editor how makes working with the new files possible again ?
PhilC posted Sat, 31 January 2004 at 8:56 AM
I get this also. I just open in Wordpad and save in plain text format. If you find that it forces a TXT extension, either edit it back in Windows Explorer, or when saving enclose the file name in "quotes".
wyrwulf posted Sat, 31 January 2004 at 9:17 AM
Turn off the file compression in P5. I don't have it, so I can't tell you how.
Holli posted Sat, 31 January 2004 at 9:27 AM
Don't know. I installed my poser yesterday. Loaded one of my own P4 characters and added it to the P5 library. The file was messed up. file compression was never turned on. If I use file compression I don't get cr2 files but crz files. If I open them with a editor it's even not text anymore.
sirkrite posted Sat, 31 January 2004 at 9:28 AM
Wyrwulf is correct! crz files will open all messed up for they are compressed.. You need to convert it to a cr2 files first. In Poser 5 Goto (EDIT) (General Preferences) and uncheck "Use File Compression" and click OK. Now open your figure in Poser 5 and resave it with a new name. The new name will now have a cr2 extention.
sirkrite posted Sat, 31 January 2004 at 9:29 AM
Oh! Never mind then. ;)
Holli posted Sat, 31 January 2004 at 9:37 AM
ok, if I open the file with Wordpad instead the editor (notepad) it looks fine. And I just found out P5 creates external obj automaticly. What an improvement !
shadownet posted Sat, 31 January 2004 at 10:04 AM
Might want to try editpad lite - its free (sorry do not have the link handy, but a google search should find it straightaway). I use to edit in notepad all the time, and early on was told that using wordpad can lead to problems when saving a cr2. Not sure, now, since it sounds like PhilC uses wordpad and he knows his stuff - hey Phil what's the real scoop?
wyrwulf posted Sat, 31 January 2004 at 10:14 AM
Attached Link: http://www.editpadlite.com/
lesbentley posted Sat, 31 January 2004 at 10:23 AM
Yes I suspect EditPad Lite may display your files corectly, and it's a great text editor.
mkrueger posted Sat, 31 January 2004 at 6:05 PM
FYI: all compressed ..z files are just zipped text. Rename the file to *.zip and extract the contained text file! martin
shadownet posted Sat, 31 January 2004 at 6:21 PM
Also you can open cz2 files with winzip without having to change the extension. Might work on other progs also, only know it works for winzip. right click on the file in WE and use the open with command. You can then view the cr2 with the internal view, and if needed copy to clipboard and paste into a text editor to be modified.
Jim Burton posted Sun, 01 February 2004 at 1:59 PM
And the answer is... Don't use anything other than Poser 4 for creating Poser content. ;-)
herr67 posted Mon, 02 February 2004 at 5:07 PM
PhilC, if you open wordpad, edit the file, then don't save but close wordpad you will get a message to save your file, save it then you will not get the .TXT added.
numanoid posted Mon, 02 February 2004 at 6:44 PM
And if we only have Poser 5?
Jim Burton posted Tue, 03 February 2004 at 2:21 PM
Well, if you selling stuff you actually aught to buy a copy of 4, honest! Otherwise your restricting yourself to the Poser 5 market, too. Poser 4 is a pretty solid program, incidently!
