Subject: This is my problem
fcanepa opened this issue on Sep 08, 2000 ยท 6 posts
fcanepa posted Fri, 08 September 2000 at 2:08 PM
Here is an image of what i get when i try to use the "Add to library" button: Any Ideas?
Mason posted Fri, 08 September 2000 at 3:50 PM
  1. your drive is fragmented or worse. Try scandisk. 2. sometimes Poser won't create a good thumbnail. especially if I just created a figure and did not assign materials to it yet. I usually get a solid black rect. 3. Are you running in 16 bit or true color mode or 256 color mode. If you're in 256 color mode, try changing res to 16 or 24 or 32 bit. 4. You could also be out of virtual memory and so the system does not create the thumbnail but won't tellyou with an out of memory error. make sure you have enough space left on your CDrive and its not maxed out. Defragmenting helps tremendously. 5. This is a good excuse to convice the wifey that you need a new computer :)
fcanepa posted Sat, 09 September 2000 at 11:32 AM
thanks... let my try defragmenting
ClintH posted Sat, 09 September 2000 at 6:26 PM
I have had this problem when I am not using the "Main Camera" when saving a new figure. If I switch to the Main Camera it seems to always resolve this problem. Just my experience with it. Good luck! Clint
Clint Hawkins
(Zakk Wylde (2007))
fcanepa posted Sun, 10 September 2000 at 1:28 PM
Ok, i've tried both things and it didn't work. I still have the same problem .. :( thanks anyway
bloodsong posted Sun, 10 September 2000 at 5:04 PM
heyas; didja see my reply on your other post? it seemed to happen to me when i had the joint editor window open. also, i know you re-installed, but did you put the patch on? mine went way after a while (either i quit using the jp window, or i put the patch on ;) ) also, the messed up thumbnail doesn't seem to affect the character, so as long as you read the name and know who it is, you're okay.
