shorterbus opened this issue on Feb 03, 2004 ยท 4 posts
shorterbus posted Tue, 03 February 2004 at 8:28 PM
Crescent posted Tue, 03 February 2004 at 8:34 PM
Is it P4 or P5? My first guess is that you have inverted normals playing havoc with the texture. Try using the Poser grouping tool or UVMapper to fix the normals. Hope that helps, Cres
Letterworks posted Tue, 03 February 2004 at 11:00 PM
I've also seen this some times if the object is double sided or if there are two planes too close together. If you've used two plans to simulate thickness either move them further apart or (and this saves memory) delete the inner vertices, you cna't see them when the object is on a poser figure anyway andleaving the edges still gives the illusion of thickness. mike
shorterbus posted Wed, 04 February 2004 at 11:20 AM
Worked! Thanks Cres and Mike!
