Nevermore opened this issue on Feb 04, 2004 ยท 18 posts
Nevermore posted Wed, 04 February 2004 at 3:08 PM
Can someone tellme some of the best ways of creaing lightning bolts in postwork? Some basic walk through explanations would be appraciated as I'm not totally familiar with both programs yet. Basically what I want to do is add in lightning bolts to an image to give either a nice storm or serious magical effect. Thanks in advance.
bonestructure posted Wed, 04 February 2004 at 3:35 PM
Get a plugin called Xenofex is my advice
Nevermore posted Wed, 04 February 2004 at 3:44 PM
Any other ways that don't involve me having to spend money I don't have on a plug in I've never heard of?
bonestructure posted Wed, 04 February 2004 at 3:54 PM
Attached Link: http://www.freephotoshop.com/html/almathera.html
Do you have Eye Candy? If you do you could draw the lightning by hand, then use the gradient glow filter to give it some light. There's also a free download of the Almathera plugin, which included a lightning maker that's quite goodTalent is God's gift to you. Using it is your gift to God.
Nevermore posted Wed, 04 February 2004 at 3:59 PM
Nope, no Eye Candy, I'll check out the Almathera link and also see what I can create by doing it by hand. Cheers
corys311 posted Wed, 04 February 2004 at 9:41 PM
There's a tutorial on renderosity in the Offsite tutes section. I used it on my Stun Gun animation... Check it out. Cory BS
retrocity posted Wed, 04 February 2004 at 9:59 PM
First make a layer and run the "clouds" filter (Filter --> Render --> Clouds)
next run the "difference clouds" filter (Filter --> Render --> Difference Clouds) on the same layer.
Open the "levels" (Ctrl+L) and slid the white slider to the left, watch the "veins" form, if they don't look right, cancel and run the "difference clouds" filter again (Ctrl+F will run the "last used" filter)
experiment with this until you get some good veins...
next duplicate the layer and invert it (Image --> Adjustments--> Invert) to give yourself a black sky and white veins.
go back to your other layer an change the "hue & saturation" (Cmd/Ctrl+U) Click "colourize" and play with the hue slider to change the colour. You may also want to adjust the saturation a bit. Make sure that preview is checked.
Select the "magic wand" tool and click on the white area, while it is selected, select the remaining white areas by choosing "similar" from the menu (Select --> Similar)
hit the "delete" key. now your layer only has the coloured veins.
duplicate this and change the "blend mode" to Overlay and run the Gaussian Blur filter (Filter--> Blur--> Gaussian Blur) making adjustment to suit your needs
you can duplicate this layer again to strenghten the glow effect...
you can also clone segments to add additional veins/bolts...
this is just an idea that may work for a "by scratch" - NO PLUGIN used method...
hope it helps
retrocity
retrocity posted Wed, 04 February 2004 at 10:13 PM
Cory, do you mean this one?
Tutorial: Lightningbolts
Description: How to make lightning bolts in photoshop whe you dont have Xenofex No plugins needed
Skill Level: Beginner
Related Apps: Photoshop 5 , 6
Submitter: By zutgorak
Date Added: Sep 17, 2001
PC Type: PC/Mac
the link seems to be dead... i get an "OOOPS" page (page missing)
ratz! cause it woulda' saved me a hecka' lot of typing!!!
retrocity
JaK3 posted Wed, 04 February 2004 at 11:22 PM
Hoofdcommissaris posted Thu, 05 February 2004 at 3:24 AM
Attached Link: Xenofex info from Alien Skin
And you can just paint them buy hand, ofcourse. With example photo's of real world lightning an shift-clicking with brushes in decreasing sizes. Copying that layer and blurring it et all. For the purists who do not want to use stuff they did not make themself. btw, Xenofex is nice of you are far-from-purist, but it will cost you some money. And it is hardly ever used professionally. See linkChuckEvans posted Thu, 05 February 2004 at 7:14 AM
I thought there was a free plugin that did this (using the clouds thingie). I'd have to be at home where I could look it up 'cause I think I got it to look at one day.
Hoofdcommissaris posted Thu, 05 February 2004 at 8:01 AM
Maybe an action?
vdallas posted Thu, 05 February 2004 at 11:07 AM
Attached Link: http://www.macdirectory.com/reviews/KPTeffects/
KPT includes an excellent lightning generator in its "KPT Effects" pluging.DreamWarrior posted Thu, 05 February 2004 at 5:19 PM
Attached Link: http://www.davrodigital.co.uk/tutorials/lightening/lightening.htm
Here is a link with a tutorial uising only layer styles. http://www.davrodigital.co.uk/tutorials/lightening/lightening.htm Hope this helps youChuckEvans posted Thu, 05 February 2004 at 6:46 PM
The plugin I was talking about was by MuRa (Cloud v 2.2) but instead of doing lightning, it was spark, I was thinking of (but it's free if you want to search around for it).
bikermouse posted Sun, 15 February 2004 at 3:05 AM
bikermouse posted Sun, 15 February 2004 at 3:23 AM
the above link is dead This links ok though: http://www.mways.co.uk/prog/plugin.php
bikermouse posted Sun, 15 February 2004 at 3:29 AM
OOPs sorry bonestructure I realized you were refering to this app after I posted. - I'll leave it up as the link is more direct.
