lucacolan opened this issue on Feb 04, 2004 ยท 10 posts
lucacolan posted Wed, 04 February 2004 at 4:37 PM
Hi everybody! Being almost a beginner in the Vue world, I'm kindly going to ask you a question. I was wondering how to create a flat area on a terrain which would have the same dimension of the bottom of my imported 3D model (without possibly fiddle too much with the brush tool in the terrain editor...). Could you also advice me on some good tutorials about anything concerning importing architectural 3D models in Vue Pro(hints, tricks, tips, and so on), thanks for your precious help Ciao from Italy
SAMS3D posted Wed, 04 February 2004 at 5:11 PM
wabe posted Thu, 05 February 2004 at 1:03 AM
The easiest way to get a flat area in a terrain maybe is to use booleans. Define a block (or whatever) and do the difference to the terrain. You should get a flat region there. Regarding importing architectural models. Well, i think it mostly is a question of testing. And maybe switching off the automatic centering and resizing for Vue in the preferences. I have good experiences with obj-files, but 3ds can work as well. The problem is, that these file-types are not totally strictly unified, therefore the output from different programs can be different when you mport them into Vue. Example. 3ds from Cinema always brings me an information window that the format is an old one and that the materials are not portated correctly. From Amorphium (f.e.) it is fine. Therefore test it with your program (AutoCad i think). hope that helps a little, Walther
Tintifax posted Thu, 05 February 2004 at 10:31 AM
You can switch off the automatic centering and resizing in Vue d'Esprit? Didn't know that. Thanks, Walther
BigGreenFurryThing posted Thu, 05 February 2004 at 3:49 PM
Is this switching off centering and resizing just a Pro thing? Can't find it in 4.
I've used AutoCAD imports into Vue 4 extensively in my work. Try the following
1 - duplicate the imported model
2 - enlarge the duplicate slightly
3 - use the enlargeed duplicate to create a boolean difference in the terrain
4 - place the imported AutoCAD model within the slightly enlarged depression
This doesn't work every time and is a real pain with large models as it slows down the PC. If possible, create another object in AutoCAD containing just the parts of the model that will be in contact with the terrain. Use that for the boolean operation. This can reduce the polygon count significantly.
My preferred method is to surround the building with lots of carefully placed smaller terrains and make extensive use of the brush tool in the terrain editor. This "hand crafted" approach gives the best look to the finished image and, with practice, is just as quick as messing about with booleans.
Hope this helps.
Cheers,
Mark
wabe posted Fri, 06 February 2004 at 12:42 AM
BigGreenFurryThing posted Fri, 06 February 2004 at 4:16 AM
I've lost count of the times I've been in the Options dialog but I've never noticed that option before. Funny the things you miss. Thanks, Wabe!
I agree that object duplication is power hungry but sometimes it works so I offered it as an option. Its efficiency depends on the complexity of the scene generally and the object specifically. My business partner is the AutoCAD wiz and he reckons that it's a doddle to create a "far, far simpler model" (his words) containing only those elements needed for the boolean.
Ultimately lucacolan's query highlights my major frustration with 3D applications: I can't find just one to do everything. Unlike 2D work where PhotoShop, or even PaintShop Pro, will do 99% of what I want, I find I need 2, 3 or more apps to complete a 3D project. Plus there's the extra work in finding the right export / import settings between apps.
OK whinge over.
Cheers,
Mark
wabe posted Fri, 06 February 2004 at 4:39 AM
Well, "the right application" depends a lot of your needs. For my work as a graphic designer Photoshop only does 10% of the business. The rest is vector work. But in 3D there is an easy solution :D. Buy a top level software like Maya and you will have everything. Only a question of money! As in real life.
BigGreenFurryThing posted Fri, 06 February 2004 at 6:38 AM
LOL. Too right about the money! Guess I'll just have to "make do" with Poser, Vue, Carrara and Amapi. ;-)
Cheers,
Mark
Tintifax posted Sat, 07 February 2004 at 3:02 AM
Thanks wabe, as I use also the german version this was quite helpful. ;-) This was really a great tip, because it solves some of my scaling issues. Thanks - Walter
