ookami opened this issue on Sep 10, 2000 ยท 4 posts
ookami posted Sun, 10 September 2000 at 8:12 PM
Anyone have problems opening the PZ3? I got all types of errors trying to find objs that were supposedly not there.
milamber42 posted Mon, 11 September 2000 at 12:32 AM
Once I got everything in the right places, it worked fine. Did your zip include a file Obj'sNeededforArmitage.zip?? If it does, then unzip it and follow the instructions in installation.txt. If not, then the readme.txt contains the locations for the other files you need. You also need the Daisy Duke character at http://members.fortunecity.com/tygerlander/ghastley/daisyduke/index.htm Be careful when you install Daisy. Tygerlander has his Poser directory as "Poser4" not "Poser 4". Hope this helps!
f91 posted Mon, 11 September 2000 at 1:58 AM
Hey, I find a little problem on the boots. All Poser 4 shoes & boots can not use litims. Also you need to change the boot shin y scale to 110, x scale to 85 & the body scale to 109 to make it fit. Hop this useful!
Wizzard posted Wed, 13 September 2000 at 5:35 AM
Loaded up no problems.... then again.. as I already have many of the obj's needed.. it went easily.. By any chance are you running a Mac Ookami? You might have to run it through a MacConverter first? I wish ye luck.. she's a beautiful figure )
