Subject: morph transfer between V3 and SP, and what items have been used questions
Aeneas opened this issue on Feb 13, 2004 ยท 4 posts
Aeneas posted Fri, 13 February 2004 at 12:03 PM
Two questions: 1/ Is it possible to transfer a set of morphs from V3 to SP, and if so, how? (I hope there is another way that manipulating the .obj file' data 2/ Is there a way to know what items have been used opn a character? I don't exactly take note of which texture, which hair, which eyes etc, and I tend to forget what I used. Not easy if I want to change something afterwards.
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
Tashar59 posted Fri, 13 February 2004 at 6:23 PM
Morph Manager will move morphs from one figure to the other, that have the same mesh. V3 to SP3, V2 to mil girls and so on. Once you do that to SP3 setting the dials at 0.500 or less seems to work better. Morph Manager can be found in the free stuff utilities. In P4, Render > Materials, will tell you what you used. In P5, The material room.
Aeneas posted Sat, 14 February 2004 at 7:24 AM
Thanks.
RHaseltine posted Sat, 14 February 2004 at 8:38 AM
Unfortunately the Materials dialogue shows only the file name, not the folder it came from. If you use P3DO from www.senosoft.com to look at your saved file, with the AWK plugin, it will list the actual path to the texture which is more likely to show the creator or package name.
