gusdrum opened this issue on Feb 16, 2004 ยท 4 posts
gusdrum posted Mon, 16 February 2004 at 8:03 PM
I am finishing short film with poser 5 and the final work is going to be a DVD. I tested with some clips and in the television screen the DVD is seen very crisp and clear, the problem in which it is seen with aspect of video and not of film. As I can obtain an aspect of film in final render of the DVD? With this I do not talk about to use a Film filter like which they come in After Effects, Premier or Vegas Video, simply to create a smoother aspect in the final video. Thanks.
texmextortilla posted Thu, 19 February 2004 at 12:15 PM
Render with an aspect ratio of 4:3 (720x540 is good)then compress at the standard ratio (720x480 for NTSC) the DVD player should be able to fix the aspect ratio itself if it's a standard file
texmextortilla posted Mon, 23 February 2004 at 5:05 PM
by the way, if you want it to be compatible with NTSC & PAL, you should render at 24 fps
gusdrum posted Mon, 23 February 2004 at 8:35 PM
Tanks for your help.
