sailor_ed opened this issue on Feb 23, 2004 ยท 23 posts
sailor_ed posted Mon, 23 February 2004 at 7:31 AM
I have been rendering some of my old images in higher resolutions. (High res? yeah right.. just enough to make an 8X10 print!:-( One has taken 6 days with the HD accessing the paging file almost continuously. Does anyone have any idea what the hardware consequences of this are? Dell notebook with 512M memory 1.6G intel. Thanks Ed
MarkBremmer posted Mon, 23 February 2004 at 8:57 AM
Hello Ed, Hi-res can mean many things! Not knowing what your settings are, doubling the size of an image can result in 4 times the render time. Before I kick of my hi-res stuff I try to minimize settings as much as possible. Unless there is some deep transparency, I reduce the ray settings to 4 vs. the default 8 and un-check all of the options I don't need (Light through trans, refraction, etc.)Why make Carrara do the math for rays I don't need. Also, changing the anti-aliasing settings from Fast to Best will cause a huge render time increase. Good is usually good enough. Same thing for the Global Illumination options. Can you see the image render progressing? If it's not advancing, I you might be the lucky winner of a rendering crash. I actually just had this happen in one of my renders because I moved a shader texture map prior to rendering. Carrara started but couldn't find the map and hung. The system was going full speed but since it couldn't locate the map, it didn't progress. Moving things back where they were fixed the problem, although I had to restart the render. Good luck! Mark
sailor_ed posted Mon, 23 February 2004 at 9:10 AM
Mark, Thanks for the reply. The settings were lowered but the poly count was just too high. It was my blackberry (ref. my gallery) image. The large number of Anything Grows objects makes for a lot of polys. The render completed ok and my machine is ok. I was just wondering if frequent hard disk replacement was something I should anticipate doing so much 3D rendering. Ed
MarkBremmer posted Mon, 23 February 2004 at 9:16 AM
Glade everything turned out ok. Never had to replace a hard drive here and I render virtually every day - mostly 15M to 30M images... I think you'll be ok! The only thing I've been "forced" to replace is slow CPU's. Mark
sailor_ed posted Mon, 23 February 2004 at 11:39 AM
Thanks. Guess I'll have to get one of those things they do the global weather simulations on. (grin)
ShawnDriscoll posted Mon, 23 February 2004 at 12:05 PM
More RAM means less virtual RAM (swapfile read/writes) which means less hard drive access. A faster hard drive means faster read/writes which means faster renders (in cases where RAM is at max size).
steama posted Mon, 23 February 2004 at 6:13 PM
I do ALL my images high resolution for print at 8.75" X 11.25" (to account for bleed --- The trim size is 8.5" X 11"). What I do is set my Carrara render output to match the Photoshop pixel size/count I am after. For example an 8.75" X 11.25" image at 300 dpi is 2635 pixels by 3375 pixel (inside Photoshop). In Carrara I set the render output pixel size to 2635 pixels by 3375 pixels at 72 dpi. That was 72 dpi NOT 300 dpi (if you input 300dpi you will be sorry). Select Keep Proportions and your image should turn out to be about 33.8 mb. Not that bad for a single image. I then render the image, usually as a tif. When the render is complete I take the image into Photoshop. The image size is 36.458 inches x 46.875 inches at 72 dpi inside Photoshop. I Then change the size to what I am after. All I do is constrain the proportions and set it to 8.75" X 11,25" at 300 dpi and I have high resolution image high enough for high end printing. It ususally does not even take very long to render.
sailor_ed posted Mon, 23 February 2004 at 9:37 PM
I was rendering 3000 pixels by 2745 at 72dpi for a .bmp file size of 23.5 mb. About 1 billion rays launched if memory serves. Which brings up the question (OT I guess) why does Carrara allow input of "dpi"? If you specify the pixel dimensions of the image the dpi is meaningless isn't it? Always Confused, ED
ShawnDriscoll posted Mon, 23 February 2004 at 11:07 PM
Pixel is for screen/monitor use. If your DPI is 72 already, then yes, you only have to tell what the dimension in pixels is. I only do 1024 x 768 pixel images for what I need (desktop background images). Maybe HDTV has more than 72dpi? If you print that 3000 x 2745 72dpi BMP image of yours on a 300dpi printer, how big is the picture? 10" x 9.15"?
Animoottori posted Tue, 24 February 2004 at 2:23 AM
I've always wondered how come changing resolution(dpi) increases rendering time if the size in pixels remains the same? If monitors and TVscreens use pixels for measuring sizes and resolution is mainly used for printing then why do they (monitors and screens) have a resolution of 72 dpi? 3000 x 2745 pixels at 300 dpi equals to 10" x 9.15" like you thought, Shonner. It doesn't matter what resolution you use while rendering. Printing at 150 dpi creates still quite sharp images if you want to get fairly good big prints with less rendering time. You are lucky to use inches in everyday life, we use the metric system here and I must always do more calculating when printing images because every program shows resolutions as dpi.
steama posted Tue, 24 February 2004 at 9:53 AM
Go into Photoshop. Find out what the image size you are after is in pixels at 300 dpi. Then go inside Carrara/render/output and enter the pixels you got from Photoshop. Keep the resolution inside Carrara at 72 dpi and then select keep proportions. Pixel aspect ratio remains at 1. Then render. The output image will be a very large 72 dpi image. Open it in Photoshop and set the inches to what you are after and then set it to 300 dpi. This method produces wonderful sharp images ready for print after you convert to CMYK of course. It works without fail everytime. No need for any extra confusion or effort. Good Luck, steama
bluetone posted Tue, 24 February 2004 at 10:01 AM
steama posted Tue, 24 February 2004 at 11:38 AM
sailor_ed posted Tue, 24 February 2004 at 12:33 PM
Right on bluetone! That simple experiment explains the whole thing. I will continue to ignore the dpi box. Slightly less confused, Ed
falconperigot posted Wed, 25 February 2004 at 3:40 AM
I suspect that it's just something the C developers intended to make more functional and then missed (like the NPR presets which aren't). The obvious thing is to have a drop down of units (in, cm, picas, pixels) so you can choose. Then the dpi would make sense.
bluetone posted Wed, 25 February 2004 at 9:16 PM
Agreed. Then the settings would all have meaning. 8.5 in x 11 in @ 300 dpi. Just what the client wanted! (I also wish they had made those presets! I've wasted a lot of time trying to figure out how to control that puppy. Made some REALLY weird images in the process! LOL!)
sailor_ed posted Fri, 27 February 2004 at 10:39 AM
It has just occurred to me what bluetone has really told us: If you enter the desired picture size in INCHES in the "height" and "width" boxes and the desired resolution in the "dpi" box Carrara does the math and comes up with the proper pixel dimensions. No Photoshop required. According to the manual (always the LAST place to look!) you can put any units in the width and height boxes. Seems to me though that a 100cm X 150cm picture at 200 dpi is really confusing at least for us Americans ;-) Ed
falconperigot posted Fri, 27 February 2004 at 11:13 AM
Does that work for you Ed? All I can enter is pixels. How do you tell Carrara that you're entering inches rather than picas or cm? Certainly the manual says you can do it but I've yet to find a way. Mark
steama posted Fri, 27 February 2004 at 11:16 AM
Hey sailor ed. I just read the same thing in the manual. I would love it if this feature would work. I am using Carrara 3. When I try to enter the desired units (inches or centimeters) it does not work. The fields won't accept input of any units of measurement, just numbers. Any tips to make this work like the manual states? steama
sailor_ed posted Fri, 27 February 2004 at 11:49 AM
Jeeeze am I a dummy. No it does not work! That'll teach me to jump to a conclusion! And to believe the manual! I will not delete my "foot in mouth" comment so that others may learn by my mistakes! ALWAYS confused, Ed
steama posted Fri, 27 February 2004 at 11:57 AM
The manual tortures all of us! Not your fault at all. LOL Have a great day, steama
falconperigot posted Fri, 27 February 2004 at 12:25 PM
Thanks Ed, you had me worried there for a moment. ;-) Here's a challenge for anyone with time on their hands. On page 564 of the C3 manual there's a nice picture of the Output Settings for the Render Properties. Here's the challenge: all you have to do is to match the numbers in the boxes AND get the same result in the Properties box, ie. width 144, height 144, resolution 200 dpi giving an image of 640 x 480 pixels. Have fun!
ShawnDriscoll posted Fri, 27 February 2004 at 6:34 PM
Carrara 3.0.3 has a bug that fills in the wrong properties for the render resolution when you open a CAR file that you rendered once already. It still remembers what resolution you used last time. It just doesn't bother displaying that info in the properties.
