Subject: SR4 Cloth Room Problems.
jwhitham opened this issue on Feb 24, 2004 ยท 10 posts
jwhitham posted Tue, 24 February 2004 at 6:06 PM
Is it just me messing up? I really hope so... Installed P5 SR4 and did a quick test. Put the long summer dress on Judy, added a pose, went to the Cloth Room and did nothing I haven't done before. The draping frames took around 5 times as long as SR3, wasn't too bothered - thought, maybe it's doing a better job. After the last draping frame though, instead of starting on the animation frames, it went stupid and just started claiming to be calculating non-existent draping frames (up to 88 of 20, before I hit cancel) whilst displaying the first zero pose frame. I've since tried all the standard P5 dynamic clothes, plus Phil C's Halter Neck, with the same result. I've even let it run on up to draping frame 470 (of 10) before killing it. I just can't make it work at all! John
xantor posted Tue, 24 February 2004 at 7:52 PM
That thing with the frames going higher than the number of frames set has only happened to me when the clothes were positioned wrongly, I mean it was my fault that there was an error.
gammaRascal posted Wed, 25 February 2004 at 1:03 AM
yup happened to me too... made a simple pose with don, took a hi res square and placed it over his head and needed over 600 drape frames to get it to drop past the neck! blew me away... wonder who else ia having some problems with the cloth room... i was using a few days ago and it worked fine...
PabloS posted Wed, 25 February 2004 at 3:52 PM
TrekkieGrrrl posted Wed, 25 February 2004 at 4:31 PM
jwhitham posted Wed, 25 February 2004 at 5:43 PM
I think I found the answer to my problem; hair! I had my question to CL tech support all written out, but decided to do some more some more experiments before making myself look an 'official' idiot by complaining about my own incompetence!
I've done enough tests now though to be pretty certain, put the hair on before the clothes and I get the problem, clothes before hair and it's fine.
To be honest, I can't be sure if I ever did the hair before the clothes with SR3, I think I did, but I can't really be sure.
John
moogal posted Wed, 25 February 2004 at 5:44 PM
So it doesn't work at all? I was only minutes from installing the patch, the so-called last patch, and now I' hearing it has broken the dynamics? I wonder is it working properly for anyone?
gammaRascal posted Wed, 25 February 2004 at 5:49 PM
yeah i did a bumcha different settings from default to all 0.0 ... chenged the stepping... the collision depth and such... i dont know what happened but like i said, 600 drape frames and it still hadent settled... try it... load don, load the hi res square and place it over dons head then goto the cloth room and setup a sim... i even tried it on the ground, it wasnt moving at all... maybe im doing something wrong... shrug that would be ahrd the beleive though since i was doing a slew of cloth dynamics just a few days ago and this never happened...
Dale B posted Wed, 25 February 2004 at 9:17 PM
I've run a test with AnAn R2, Hmann's dynamic dress, and dynamic ponytail. Aside from the hand snagging the dress and yanking it partially off the figure around frame 268 (using a couple of Santa Monica Studio BVH's tweaked together), the cloth room has been working better for me than ever. I did move that backup folder out of the P5 tree, and it is a new install with only SR-3, SR-3 figure updater, and SR-4 installed. Off the top of my head, I would suggest checking to make sure there aren't =any= cloth-model intersections. All it takes is one vertex or polyline violating the collision conditions, and you will never get a conforming (when the hand broke through into the dress mesh, the dynamics froze at that point; it still followed the figure, but that was all. No further deformations). Oh well, off to tweak at the BVH file yet again, see if I can't prevent the rip; up to that point, that dress was performing perfectly....
Dale B posted Wed, 25 February 2004 at 9:28 PM
Oh, and anyone who wants a gorgeous Judy to play with, go to Yamato's site and download AnAn.
