DanielChicago opened this issue on Sep 16, 2000 ยท 4 posts
DanielChicago posted Sat, 16 September 2000 at 2:03 PM
DanielChicago posted Sat, 16 September 2000 at 2:04 PM
This is just a book cover I grabbed to illustrate the problem. The smaller thumbnail is taken from Amazon.com to show what the cover is supposed to look like. Please help if you can! Thanks
jnmoore posted Sun, 17 September 2000 at 8:43 AM
The image appears to be inverted. Check your scanner settings to see if your are set for "color negative" and reset to "color posative" or "reflective". You can check for this by scanning into PhotoShop (without changing any of your settings), then click on the Edit Menu, Adjust > Invert. If the image looks normal now, change your scanner settings as suggested above. If it doesn't, I'd suggest you contact the manufacturer of your scanner for further advice. 'Hope this helps you.... Jim Moore
DanielChicago posted Sun, 17 September 2000 at 12:46 PM
Jim, Thanks for your suggestion. I tried inverting the settings, but no luck. I think it's more technical, so I guess I will contact Canon and ask for their assistance. Thanks anyway. :-) Daniel
