Yunas_Guardian opened this issue on Feb 26, 2004 ยท 7 posts
Yunas_Guardian posted Thu, 26 February 2004 at 10:41 AM
Yo. I'm miffed. I've recently begun using C4D and obviously I'm trying to move some Poser figures o'er into C4D. The problem is material zones are getting all messed up. Example! I tried to move Hankster's Eclipse vehicle to C4D and the maps weren't were they were supposed to be. I can't remember, but like the hood was on the side door or something of that nature. I've only tried to do this a few times, so it is very possible I am screwing something up in the conversion process. I'm exporting as .OBJ and then opening in C4D. I'm using Poser 4 and Cinema4D r8. So, what happened? Help would be much apprecited since I got carpel tunnel in my wrist whilst putting textures on a figure that had around 35 material zones. Then I saw they were all messed up! Damnit. lol. Ciao. Thanks in advance for any help.
xantor posted Thu, 26 February 2004 at 11:29 AM
Attached Link: http://www.curiouslabs.com/article/archive/65/?df=1
Curious labs has a free cinema 4d plugin it is for version 7 but it might work with version 8. You can get it at the link.Estruch posted Thu, 26 February 2004 at 11:37 AM
This pluggin only run with the version 7.3 of Cinema and Poser Pro Pack 3 release,. Not run with Cinema 8. I use this something times and run very well.
FreeJack posted Thu, 26 February 2004 at 12:30 PM
Hey, I talked to someone a while back about getting poser stuff into C4d, and he suggested the following: 1: Set up all the stuff as you like it in poser. Get it all just right. 2: Export as an .obj. 3: Use the plugin at http://www.renderosity.com/freestuff.ez?Form.Contrib=Niki&Topsectionid=0 to set the textures. Hope this helps! Jack
Fredy posted Thu, 26 February 2004 at 1:38 PM
A few tips: Check the ReRo-Cinema-freestuff-area for jddog's-Tutorial. Or here: http://www.renderosity.com/tut.ez?Form.ViewPages=508 Or check those links: Poser to Cinema without plugin: http://arcana.daz3d.com/index.php?id=143 Poser to Cinema with Niki's magnificent plugin: http://www.mazak-grafikwelt.de -> forum -> cinema -> Amazones plug-in tutorial for use with Cinema 8.2 Niki is also MOD over at Mazak's forum... The CuriousLabs-Plugin is... "useable" but Niki's plugin is much better! Check my gallery, all pics are made using Niki's plugin... Does this help? ;-)
Shoshanna posted Thu, 26 February 2004 at 6:29 PM
Attached Link: http://www.renderosity.com/homepage.ez?Who=jddog
jddog has an excellent pdf tutorial as his featured freestuff item on his home page. It is for Poser 5 to Cinema 4d r8.5 ShoshannaYunas_Guardian posted Sat, 28 February 2004 at 12:15 AM
Awright! I'll check each of these out! Thanks to you all!
