Subject: Making things stay where you want them.
ssalter opened this issue on Feb 26, 2004 ยท 4 posts
ssalter posted Thu, 26 February 2004 at 3:03 PM
I could have sworn I did this before but can't figure it out now. Poser4Pro is the package. V3 is the figure. The Kirstie hair is great but when you conform it to "figure 1" it slips down. Same thing with the headdress from The Last Princess by the BVH Studios. When I add those to the figure, they appear in the right place but when I conform them, they go awry. Of course, if I don't conform and I add a pose to my figure, they don't follow. I've tried pointing them to parent "head", lock actor, and so on. I'm missing something here. How do I "lock" them where they should be AND why don't they conform the way they should? thanks, Steve ps: While I am at it...if I want to apply a pose to my figure, and mistakenly have hair, clothing or whatever selected, is there anyway to recover from this? There is no undo for this sort of mistake.
EnglishBob posted Fri, 27 February 2004 at 4:29 AM
Attached Link: http://www.thenetherworks.com/
The Last Princess is for Victoria 2; I couldn't find Kirstie, but I suspect the same is true here. You need the V3 center setter from Netherworks, which usually does the trick. The full V3 conformer pose might be needed in some cases; better get that while you're there. ;)
ssalter posted Fri, 27 February 2004 at 7:12 AM
I mispelled it...Kristie hair. It probably is for V2 as well though, as you say. I grabbed the Netherworks utilities. The "full V3 conformer pose" is the V3 Clothing Conformer, or is that something else? Thanks!
rreynolds posted Fri, 27 February 2004 at 2:21 PM
Sometimes the hair can be parented to the figure by going to FigureSet Figure Parent.
