wrpspeed opened this issue on Feb 26, 2004 ยท 7 posts
wrpspeed posted Thu, 26 February 2004 at 4:45 PM
wrpspeed posted Thu, 26 February 2004 at 4:53 PM
i tried it with a tree prop. it worked. i am baffled. i wonder if there is a poser file size limit on importing. the 2 figure file was 65 mg. the tree was only 102k
agiel posted Thu, 26 February 2004 at 11:06 PM
There are limitations with some types of geometries or props attached to a poser object. Vue also doesn't react well sometimes to scenes with multiple figures. When this kind of error shows up, you can try making copies of your poser scene with less and less objects included. When the scene is finally imported, that will give you a hint about what caused the error. Sometimes it is as simple as saving a prop and importing it separately.
estherau posted Fri, 27 February 2004 at 4:05 AM
But I've got the same problem since the latest beta upgrade, and I used to be able to import the same things before. Now the PZ3s don't come in. Love esther
TheWingedOne posted Fri, 27 February 2004 at 6:37 AM
I don't have any problems with Poser5 imports at all. One thing you could try is to split the scene into two or thre parts and import them seperately. This is just an idea, but it might work. :) Cheers, Phil
estherau posted Sat, 28 February 2004 at 10:36 AM
Hmm, the poser scene I'm trying to import is only 1.5 megabytes. YOu can import that sort of size all in one can't you Phil? Love esther
jwhitham posted Sat, 28 February 2004 at 7:24 PM
wrpspeed: looking at your error message, I'd say it's a path problem. Desktop and My Documents can be useful places to put files you want to keep tabs on, but in my experience they just don't work properly if that file contains relative paths to other files upon which they're dependent. Try saving an MS Excel sheet in Desktop when it has links to others, it'll never find its links. Poser files contain links to external geometry and texture files, if they're not on the desktop too, it won't find them. Save your file somewhere in the Poser runtime for best chance of success!
