kusanagi73 opened this issue on Feb 29, 2004 ยท 11 posts
kusanagi73 posted Sun, 29 February 2004 at 12:42 PM
When I attempt to render in a new window, I get the above message. However, I have lots of RAM and disk space. I had this problem last year, and I remember it was solved with a very simple solution, but I cannot remember what. Kusa
geoegress posted Sun, 29 February 2004 at 1:10 PM
hi Marg- that is Poser default error message when it dosn't know what is happening. Try to defrag first. If that dosn't help- run correct referance- it might not be able to find something. Then- if that dosn't work- try moving things around a little- Then - if THAT dosn't work- one at a time delete things untill you find what is causeing it.
kusanagi73 posted Sun, 29 February 2004 at 2:06 PM
Thank you Ken! I moved some things and it seems to be working for now. I'll have to write these down, just in case this issue pops up again. ^_^
nakamuram posted Sun, 29 February 2004 at 2:26 PM
Write down you virutal memory settings, then set your virual memory to 0 and reboot. After rebooting set your virtual memory back to your original settings and reboot again if you have to. If you still cannot render, delete Poser/runtime/prefs/preferredState.pz3
SamTherapy posted Sun, 29 February 2004 at 4:51 PM
This is a copy and paste from the CL website: Poser 4 can't render high resolution images. Error appears "Insufficient disk space to render". After some intense investigation we believe we have a work around. It turns out that Windows NT 4, 2000 and Windows XP must be using some space for the pagefile.sys file on the same partition that Poser is installed, to render large images. The pagefile.sys is the virtual memory or temp space for Windows. An approximate minimum would 10 MB. This amount might have to be increased for more complex scenes and animations. The maximum should be 10 MB or greater. To modify the Virtual Memory: Windows NT 4 = Right Click my computer. Click the performance tab. Click change. Click the drive Poser is installed on. Enter 10 in the Initial size field. Enter 500 or more, in the maximum size field. Click set. Click OK. Click OK. Click OK. Restart the System. Windows 2000 = Right click My computer. Select the Advanced tab. Click Performance option. Click Change. Select the drive Poser is installed on. Enter 10 in the Initial size field. Enter 500 or more, in the maximum size field. Click set. Click OK. Click OK. Click OK. Restart the System. Windows XP = Click Start. Right Click My Computer in the menu. Select Properties. Select the Advanced tab. Click Settings, next to Performance. Select the advanced tab. Click Change. Select the drive Poser is installed on. Click the Custom size button. Enter 10 in the Initial size field. Enter 500 or more, in the maximum size field. Click set. Click OK. Click OK. Click OK. Restart the System. Poser will now be able to render up to its maximum size of 4090 pixels x 4090 pixels @ any resolution
Bobbie_Boucher posted Sun, 29 February 2004 at 11:02 PM
Ok, really the simplest fix is to install Poser on a different drive from Windows. You will rarely get the message after that. If you do, it is time to defrag.
JohnRender posted Mon, 01 March 2004 at 10:57 AM
Geez, has it been a week already since someone asked this question?
Poser 4 has been around since, what, 1999? 2000? So why do people think that they are the first person to have this issue? Why do they post a new message (and get 4-5 answers) when there are TONS of messages about this issue?
Searching on the word "insufficient" turns up the following: (this doesn't count any threads where the person spelled the word "insufficeint").
1/30/04 - By Phantast
Re: Does altering a non-commercial item make it legal to use in commercial rend
1/26/04 - By crowbar
Re: Insufficient Disk Space question
1/16/04 - By crowbar
Poser Tip : memory and Hard Drive "virtual memory"
1/6/04 - By pjanak
Re: Infuriating "Insufficient memory to render at current resolution" error
12/5/03 - By bjbrown
Re: About to Buy Poser but have 2 questions
11/29/03 - By JoeyAristophanes
Re: Pathetic plea from new to mac user :-(
11/26/03 - By Bobbie_Boucher
Re: "insufficient disk space" message AGAIN!!
11/14/03 - By iggy23
Re: insufficient disk space to render at the current resolution
11/8/03 - By Zarabanda
Re: GRRR please someone that knows how to fix this pllllllllllleaaaaaaaaase
10/23/03 - By cappy3
P4 Tech Problem
10/7/03 - By Yamato
How about P5 Judy? Wanted ! your opinion.
10/6/03 - By EnglishBob
Re: Will increasing my virtual memory make Poser work faster?
9/29/03 - By JVRenderer
Re: Fantasy Bow Problem
Re: Quarker's Hairs
8/9/03 - By EnglishBob
8/3/03 - By SamTherapy
Re: rendering error messages
8/2/03 - By ragmanjones
Re: Poser V4 Memory "Hint" and Comment...
7/30/03 - By dialyn
Re: Textures! Argh!
7/28/03 - By ljudice
7/27/03 - By blunx
looking for opinions from Poser animators w/ Vue+Mover experience
7/27/03 - By kuroyume0161
Re: Stolen Artwork, might be yours (go to the Copyright Forum)
7/21/03 - By dlk30341
Render problems need some help please
7/15/03 - By spurlock5
Re: Anyone here use 3D studio Max/
6/29/03 - By Placebo
Re: memory help
6/25/03 - By nomuse
Re: Nice to see the art of trolling isn't dead
6/9/03 - By agiel
Poser 5, XP and 1Gb of RAM... and still freezes ?
6/6/03 - By nikitacreed
Re: Recognize any of these images????
5/29/03 - By Replicant
Help! Help! Its lying to me!
5/27/03 - By Nance
Re: Rendering Problem
5/25/03 - By nakamuram
Re: keep getting an "insufficient disk space" message
5/10/03 - By queri
Re: Poser 5 Service Release 3 is now available
4/9/03 - By queri
Re: Render Problem
4/6/03 - By BeatYourSoul
Re: Render problem after conversion to NTFS
4/1/03 - By mrp2284
Re: Insufficient Disk Space to Render at the Current Resolution?!
3/20/03 - By PeterWahoo
Re: Help! Reinstalled ProPack and Strange Things are Happening
3/9/03 - By Spit
Re: Insufficient Disk Space BS
2/25/03 - By Nance
Re: Richabri's rock stage - Really worth a look!
2/20/03 - By cinevid
Long time "Lurker" needs help
2/10/03 - By queri
Re: No disk space in the current resolution...
2/10/03 - By SamTherapy
Re: Poser User Interface Stability?
2/4/03 - By queri
Re: "Insufficient disc space for current render"
1/9/03 - By bitplayer
Are you SURE it's unethical?
1/6/03 - By GhostWolf
Help needed
1/5/03 - By queri
Memory fix!!!
1/1/03 - By jwhitham
Re: Objaction Mover - range check error
12/27/02 - By queri
Insufficient memory fix
12/23/02 - By denden
Re: Maximum size image
12/18/02 - By kramer99
Be Careful....Major Credit Card Problem Ordering Poser 5
11/13/02 - By Kelderek
Re: recommended hardware?
11/12/02 - By Nosfiratu
***** CURIOUS LABS RELEASES POSER 5 SR-2 BETA 4 *****
10/28/02 - By jval
Re: The Tailor and MIMIC: DAZ can we ever expect Poser 5 compatibility?
10/25/02 - By DefaultGuy
SR2-2 Beta release is now available
10/18/02 - By queri
Re: It must Friday cause it;'s time for the Memory fix-- Again
10/16/02 - By kupa
CURIOUS LABS RELEASES BETA SERVICE RELEASE 2 FOR POSER 5
10/16/02 - By Crescent
sr2 beta 1 info from CL web site
10/13/02 - By lordbyron
Re: Look who's coming to dinner!
10/13/02 - By hankim
Re: Render out of memory problem. I need help please...
10/9/02 - By jval
Re: WTB's State of the Poser Union
10/4/02 - By Himico
Poser5 problem---please help.
10/3/02 - By Corum_Anime
HELP! "Insufficient disk to render at current res"
10/2/02 - By Nance
Re: A nother Newbie question - - - sorry
10/2/02 - By narsil
Re: P5 rendering problem
9/30/02 - By kupa
Poser 5 updater status
9/25/02 - By Tempus Fugit
P5 won't render big - arrgh
9/18/02 - By hankim
Re: Not enough memorty error
9/13/02 - By queri
Time to once again post the XP-- and others-- fix.
9/10/02 - By lordbyron
Re: Open letter to Curious Labs
9/8/02 - By isaacnewton
Re: When? poser5 shipments question for CL people
9/4/02 - By AliasAngel
insufficient disk space???
8/27/02 - By xoconostle
Re: Memory problems
8/21/02 - By Orio
Re: European Poser 5 Customers = "Dumbass"?
8/21/02 - By reiss-studio
8/19/02 - By demosthenes_aborigin
Re: where can I find togas or other classical Greek outfits?
8/17/02 - By crisjon1950
Re: I'm having trouble.
8/3/02 - By queri
Insufficient memory Fix
7/31/02 - By Eric Walters
Re: Poser newbie ready to bang her head against a wall...
7/13/02 - By ronknights
Re: A tip for anyone who's as dumb as I am...if that's possible. :-)
7/12/02 - By ronknights
7/4/02 - By serpentis
Re: Insufficient Disk Space...
6/13/02 - By ronknights
Re: Out of Memory Problem
Re: Placement of runtime folder during defragging...
6/13/02 - By xoconostle
Re: Rendering times and what goes into them (need info)
6/13/02 - By kuroyume0161
Re: template ?
6/12/02 - By sergemarck
Re: Back to period fashion
6/10/02 - By ronknights
Re: Please help-- how much space does Poser Need to render?
6/9/02 - By hendrikm
"insufficient disk space" while rendering
6/9/02 - By queri
6/1/02 - By ronknights
Re: Just about had it with Poser
5/30/02 - By ronknights
Re: Ok, ok, so I just had to know!
5/24/02 - By JoeBlack
Re: ok, could anyone tell me what's wrong with this MAT???
5/18/02 - By soulhuntre
Re: Insufficient disk space to render fix?
4/25/02 - By ronknights
Re: Memory issues with Poser
4/24/02 - By 6Dprime
Re: Poser blight?
3/26/02 - By lukedesade
Re: Newbie question on props
3/24/02 - By boblowery
Re: Rendering Crash
2/19/02 - By ronknights
Re: Ring my bell - Why does Poser keep doing it
2/18/02 - By Eowyn
Re: Things about Poser that make me go aaaarrrrrrrggggggggghhhhhhhh!
2/10/02 - By ronknights
Re: SteffyZZ and Windows98SE
2/4/02 - By Eowyn
Re: Daz Hi-Res Textures
1/19/02 - By PabloS
Re: Odd error message
1/11/02 - By JimYount
Help on rendering larger files on Win2K
12/25/01 - By Bevel
Re: Insufficient Disk Space... URGENT!
12/17/01 - By soulhuntre
Re: Insufficient disk space to render at current resolution?
12/17/01 - By JABevan
12/14/01 - By JABevan
Re: Insufficient disk space error, help me
Re: Possible fix for "insufficient disk space to render at current res" issue
Re: Render error: Insufficient Disk Space to Render at This Resolution
12/9/01 - By tritorella
Re: Memory problems while rendering - MAC
11/3/01 - By ronknights
Re: Memory error (PC), Help! (new user)
10/31/01 - By dkirk
New features in version 6.1
10/25/01 - By curtechman
FIX_WORK AROUND forInsufficient disk space to render at current resolution?
10/19/01 - By ronknights
Re: Adding Memory To Poser
10/7/01 - By Marque
Re: LifeForms Who uses this program?
8/16/01 - By duanemoody
morphability of P4 characters
8/16/01 - By Nance
nakamuram posted Mon, 01 March 2004 at 3:47 PM
There will always be new users who don't know where to look for an answer to this problem. Maybe there should be a P4 and P5 problems FAQ somewhere at Renderosity. Others on this thread including myself have answered this question several times. We'll gladly do so again.
Bobbie_Boucher posted Mon, 01 March 2004 at 6:36 PM
look at the top of the Page, and you find FAQ.
nakamuram posted Mon, 01 March 2004 at 7:20 PM
This topic definitely belongs near the head of the list.
queri posted Mon, 01 March 2004 at 9:18 PM
I have asked in the past to have that fix-- the CL one-- put in the backroom under tips or FAQs or something. It does come up often. As you can tell from that long list, I dont mind answering it over and over again. I have it on a notepad on my desktop for such emergencies. Sharon beat me this time.:)) The CL fix is weird but it works. Emily
