Subject: figurs wont hold hands
mattbaby opened this issue on Mar 01, 2004 ยท 4 posts
mattbaby posted Mon, 01 March 2004 at 1:04 AM
Attached Link: http://MattBaby.com
how do i make them hold hands. i read the manual and it is not in there how do i set them to parent to eachother? IM me at PresPT352
EnglishBob posted Mon, 01 March 2004 at 7:07 AM
You really only need to manoeuvre the hands to be in the right position (which is easier said than done, mind you). Parenting is not necessary unless you're doing some advanced animation stuff. How to get hands in the right place: Select the hand you want to move. Turn on Inverse Kinematics (IK) for that arm. The hand will now have translate dials which you can use to pull it this way and that. The arm joints will adjust automatically as long as you don't go too far. Use the hand camera to get a better view.
mattbaby posted Mon, 01 March 2004 at 11:14 PM
Attached Link: http://mattbaby.com
how do i turn on this "inverse kinetics"? I am using poser5 and i am not sure if that featre is included that i can find :( IM me at PresPT352
EnglishBob posted Tue, 02 March 2004 at 5:13 AM
In Poser 4 it's in the Figure menu - don't have P5 so I'm not sure if it's the same. There's always the manual if all else fails. :)
