Fri, Nov 29, 2:03 AM CST
Renderosity Forums / Bryce
Welcome to the Bryce Forum
Forum Moderators: TheBryster
Bryce F.A.Q (Last Updated: 2024 Nov 26 4:28 pm)
[Gallery]     [Tutorials]
THE PLACE FOR ALL THINGS BRYCE - GOT A PROBLEM? YOU'VE COME TO THE RIGHT PLACE
Subject: Lighting ????
kiwi_gg ( ) posted Mon, 01 March 2004 at 10:19 PM ยท edited Fri, 15 November 2024 at 12:18 AM
I have been "dick'in" around with this scene for ages. Inspired by AS's Diver scene And using his Tut as a guide I have got this far. What I want now is for the spotlights on the deep sea scout vehicles to appear that they are cutting through the cloudy water from the scouts to the lit up areas on the wreck,much as car headlights do in fog. Can anyone help,I have tried a hundred different settings in the light lab without success. Any comments about the overall scene welcome. You can be brutal,I have a really thick hide.
Cheers
GG.
WHO said Kiwi's can't Fly ?????
AgentSmith ( ) posted Tue, 02 March 2004 at 3:20 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1154814
Volumetrics can sometimes just plain suck to do. Sometimes, with a couple clicks it's great, and other times I'll struggle forever... Basically, when I do them inside of Bryce, I go the classic way; use a elongated primitive with a volume light mat applied to it, and a spotlight inside. BUT, sometimes I find it easiest to just activate the option on the spotlight; "Visable Object - Volume", and then start bringing down the intensity, until it works/looks right. It's pretty much different for every scene. Here's a link to a forum thread where I put up a link to download a volumetric cone scene I made, maybe it will help? It uses a spotlight inside a cylinder with a volume mat on it. AgentSmith
AgentSmith ( ) posted Tue, 02 March 2004 at 3:23 AM
Here's a couple of link in which I did the Light Rays in post-work 2D. http://www.renderosity.com/messages.ez?Form.ShowMessage=1599987 http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=1344735 AS
gammaRascal ( ) posted Tue, 02 March 2004 at 8:28 AM
try this off the top of my head turn one of your spots into a volume visible... infinite then go to ranged (click it) and set it for just a guessing at your scale about 100 or 200... if it shows up in your render and the scale is good then play with the lights edge softness... keeping in mind, this will also shorten (view aperant) your light, so you might have to increase the range some... i think though, in this case, i would use a surface visible spot light instead of a volume one... i only say that because if your not trying to take advantage of the 'volume' effect (that is to say, to break the volume and cast shadows within the light) then a surface visible might be best and easier to render... again just off the top of my head... good luck!
kiwi_gg ( ) posted Tue, 02 March 2004 at 9:42 PM
Thanks heaps guys,I will play with your suggestions and view the links but after putting up the post I decided that the one thing I had'nt tried was a "Gel" and bingo there it was. 18 hours of rendering later here I have the Desired effect and I'm sure with a bit more tweaking of the Gel it could be perfect,but that will have to wait a wee while as work demands are pretty intense this month.
Cheers
GG.
gammaRascal ( ) posted Wed, 03 March 2004 at 9:35 AM
mmm.. the light kinda falls off there... shrug i liked the how it ignited the deck of the ship on your first image. also the two light dont seem consistent, that is to say, the closest 'sub' has a wide-short stream and the furthest 'sub' has a short-thin stream... either way, looks good. glad it worked out.
kiwi_gg ( ) posted Wed, 03 March 2004 at 11:26 AM
I agree with all of what you have said,I prefer the way the lights hit the deck in the first image. The difference in the shape of the lights is more to do with the attitude of the vehicle as both sets of lights are the same type,settings and position on the vehicle. I will be tweaking the image as time permits, I want the water to have a little "dirtier" colour as well. Cheers GG.
