Xanetianna opened this issue on Mar 02, 2004 ยท 8 posts
Xanetianna posted Tue, 02 March 2004 at 2:09 AM
TrekkieGrrrl posted Tue, 02 March 2004 at 2:26 AM
The shadow is there becourse the transmap isn't 100% black or becourse it isn't at 100%. Check the transparency settings, and look out for any falloff other than 0.0 Some versions of P5 had the falloff at 0.6, this could give the shadow you're expiriencing.
Xanetianna posted Tue, 02 March 2004 at 2:48 AM
thanks just one more thing...where do I go to adjust that?
hauksdottir posted Tue, 02 March 2004 at 3:00 AM
Also, it looks as though there is "poke through" just under her breasts.
TrekkieGrrrl posted Tue, 02 March 2004 at 3:00 AM
In the material room. Select the dress and look for the neck/chest/whatever part. Then check the transparency setting on that :o)
TrekkieGrrrl posted Tue, 02 March 2004 at 3:03 AM
And yes, Hauksdottir, I noticed that poke-thu too :o) But as it wasn't the subject for the question... Anyway, you must use the same morphs on the dress as you used on the character. Unfortunately this is the downside of Poser 5's elimination of cross talk - Morphing clothes no longer automatically morphs with the character.
TygerCub posted Tue, 02 March 2004 at 4:37 AM
Besides the transparency and fall-off issues mentioned above, also make certain the highlight and reflection dials are at 0 for the transparent area.
semidieu posted Tue, 02 March 2004 at 5:36 AM
An easy trick to transfer the morph is to use the Ctrl-C/Ctrl-v technique.... Select the body of the figure, type Ctrl-C Select the body of the dress, type Ctrl-V Certainly it's a well known trick... but it help sometime to refresh a little bit memory ;-)
