Subject: Texture Folders
arrow1 opened this issue on Mar 10, 2004 ยท 7 posts
arrow1 posted Wed, 10 March 2004 at 2:22 PM
Can anyone tell me if it matters whether you open the texture folder or save the whole folder in textures when a product is downloaded and installed. For instance some products when bought are extracted into poser automatically, and a folder appears for that product in the textures folder under the product name.Do I leave that folder as is? or do I open it and extract the contents under the product texture name? It seems to me some render ok and some have to be opened.Daz products for instance have a lot of folders in their texture folder from everyhing from clothes to character and prop textures.arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
steveshanks posted Wed, 10 March 2004 at 2:43 PM
As long as a texture is inside Runtime/textures poser will find it....it might only need to be in runtime actually but runtime/textures i'm sure of..so you can put them anywhere in there ...Steve
arrow1 posted Wed, 10 March 2004 at 3:01 PM
Many thanks for your reply steve! I have been using Poser for over two years now and was never sure which was correct.cheers arrow1
diolma posted Wed, 10 March 2004 at 4:32 PM
Arrow - Poser WILL find them, but it'll take it's own sweet time about it. If you really want to move the texture elsewhere, edit the relevant cr2/pp2 file, find the references to the texture and change the path (back up the original 1st!). On my system, if Poser can't find the texture where it expects it, it can take up to about 30 seconds for it to work out where it is... Cheers, Diolma
SWAMP posted Thu, 11 March 2004 at 1:43 AM
CorrectReference (found in free stuff)will batch correct all your Poser files (cr2,pz2,etc.)to the location of your textures. No need to hand edit your files as this does it for you. Run it on just one library at a time,as it does take several min. to do it's job. Once your done,you'll find all your textures will load faster. SWAMP
arrow1 posted Thu, 11 March 2004 at 2:07 AM
Many thanks all! arrow1
TrekkieGrrrl posted Thu, 11 March 2004 at 4:13 AM
Takes several minutes?! Try HOURS! Oh yeah... Last time I ran a Correct Reference on my complete Pose library it took over 24 hours. Several times I thought the program had frozen but then it munched thru yet another file O.o It found a LOT of bad references. And this was even my DAZ folder :o/ where they SHOULD be ok and tested and all. But they weren't. And I'm not just counting the instances where CR wants to correct something like TrekkieGrrrl into trekkiegrrrl. (Howard if you read this, PLEASE make the "change all to lower case" optional in CR Pro)
