deacali opened this issue on Mar 12, 2004 ยท 4 posts
deacali posted Fri, 12 March 2004 at 5:27 AM
How can I apply boolean operations to obj files imported into Bryce from Poser?
Zhann posted Fri, 12 March 2004 at 6:27 AM
I suspect the same way you would for any Bryce object, select an object make it positive, select the one you want to cut with , make it negative and group them...if that's wrong, I'm sure someone will correct me
Bryce Forum Coordinator....
hutchingsm posted Fri, 12 March 2004 at 6:45 AM
pauljs75 posted Fri, 12 March 2004 at 5:04 PM
Also note that on some objects the solid setting may affect how internal normals are rendered. Some meshes with holes in them, normal backsides may disappear if set to solid. (At least it does in Bryce 4.)
