selkins16 opened this issue on Mar 16, 2004 ยท 5 posts
selkins16 posted Tue, 16 March 2004 at 12:06 PM
Hi everyone! Could anyone tell me please if I'm missing something basic when using a blue background in my Poser images so that I can add another background in Photoshop. I am having trouble with the blue (or green) showing through the hair or things like transparent fairy wings, and when I use the magic wand to select the blue, it doesn't select the blue in these areas or if it does and I delete it, I get all kinds of jaggies and holes. Does this make sense? :) I'm setting my magic wand at 30 or 40 tolerance and turning off anti aliasing. I'm also using a brilliant blue or green like I've read I should use. Thanks in advance for your advise! Have a great day! Shelly
visque posted Tue, 16 March 2004 at 12:11 PM
You would be better off rendering the Poser scene as a tif files. You can, using channels in Photoshop, get a clean transparency.
Jackson posted Tue, 16 March 2004 at 1:14 PM
Correct. Saving as tif, psd, and png automatically saves an alpha channel. With your pic in Photoshop, open the channels palette and ctrl-click on the last one (the alpha channel). I don't remember now, but you might have to invert the selection (ctrl-shift-i) to select the background. Also, make sure you render with anti-aliasing ON in Poser. This will greatly reduce jaggies.
SWAMP posted Tue, 16 March 2004 at 1:17 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1272436
Shelly,you'll never get it right useing the magic wand,but useing the alpha channel will give you perfect results. Doing this the background color doesn't make a different (I always use black for my background color). Follow this link to a thread in the Photoshop forum,and scroll down to my post,where I gave a step by step,to what you want to do. It's VERY easy to do...take you all of 15 sec. to get a perfect cutout. Hope this helps,SWAMPselkins16 posted Tue, 16 March 2004 at 1:38 PM
Oh you all are awesome! Thank you, thank you, thank you...I've been struggling with this for quite a while!!! Hugs! Shelly
