Forum: Photoshop
Subject: a transparency question
HorseFlesh opened this issue on Mar 18, 2004 ยท 7 posts
HorseFlesh posted Thu, 18 March 2004 at 6:03 PM
Hi folks. Is there a method to make a layer gradually transparent in Photoshop? I do this easily with a built in tool when I use Photopaint 11, but dont know how it is done in PS. It is really the only reason I still use corel software at all. For that one tool! Anyhow, I really need some pointers... Thanks-Ryan-
Lapis posted Thu, 18 March 2004 at 6:09 PM
Yes. When you gou look at your layer there will be an opacity setting. Play with it. It ranges form o to 100%, 0 being totally transparant (invisible) to 100% being totally opaque.
HorseFlesh posted Thu, 18 March 2004 at 6:33 PM
I know about that way, this is more what I was wanting to know....To fade out the layer from a certain point in that layer...like in the image above. Thanks-
Lapis posted Thu, 18 March 2004 at 7:31 PM
Ahhh okay. There are likely several ways to go about this. What comes to mind first is to apply a custom gradient (make it how it will best contol how you need the transparency to be modulated) and apply it to a opacity mask. Then adjust it's opacity level over top of the layer you want to affect.
Hoofdcommissaris posted Fri, 19 March 2004 at 5:27 AM
It's really as easy as 1, 2, 3 1. create a mask (the circle in the square symbol) 2. select the gradient tool (which looks like a, well, gradient) 3. pull it from left to right, or otherwise, in the mask
HorseFlesh posted Fri, 19 March 2004 at 9:30 AM
Thankyou very much! Now I don't have to leave Phptpshop to do this!Thanks again... Ryan-
Boxx posted Fri, 26 March 2004 at 12:37 PM
If you just want a graduated selection, use the Quickmask (Q key) and use a black to clear grad. Switch Quickmask off and you can paint into it or make a layer mask.
