Subject: What does a Mac user do with pcf?
Barbarellany opened this issue on Mar 23, 2004 ยท 8 posts
Barbarellany posted Tue, 23 March 2004 at 4:02 PM
I downloaded something that has a pcf file. I have the seed fire but obj mover is not for mac. What do I do?
Estruch posted Tue, 23 March 2004 at 4:20 PM
Attached Link: http://www.soft-rabbit.com/
Use Maconverter.
Ajax posted Tue, 23 March 2004 at 5:17 PM
Does Mac converter handle pcf? I thought pcf files were pretty much off limits for Mac users.
View Ajax's Gallery - View Ajax's Freestuff - View Ajax's Store - Send Ajax a message
dbutenhof posted Tue, 23 March 2004 at 5:56 PM
It works with most, anyway, though I've heard suggestions it doesn't work with all. What it doesn't do is RTE. But RTEJava takes care of that. Of course it'd be nice to have them combined; along with something that can fix those old rsr files without running Classic. With Poser 5, those 3 functions are all that's needed.
Triarius posted Tue, 23 March 2004 at 6:55 PM
What is RTEJava?
Ajax posted Tue, 23 March 2004 at 7:39 PM
RTE is an encoding system used to distribute modified versions of copyright protected mesh - ie it does the same thing as pcf, just in a different format. I haven't heard of RTEjava before but I assume it's a version of the RTE software written in the programming language, java, which is platform independent - so you can run it as easily on a Mac as on a PC Still no help for decoding a pcf file on a Mac though.
dbutenhof posted Tue, 23 March 2004 at 8:03 PM
RTEJava was written this year by Mark Davis. I suspect it's in Freestuff; but you can also get it at http://www.geocities.com/RTEJava/alpha/
It works well, with the advantage that you should be able to run it anywhere with a Java implementation.
Barbarellany posted Tue, 23 March 2004 at 9:37 PM
Maconverter worked. Thanks so much.
