Brooke opened this issue on Sep 23, 2000 ยท 5 posts
Brooke posted Sat, 23 September 2000 at 9:14 PM
I can't get to seem to get transmaps for hair to work right. I've set max and min to 100% and played with the falloff but instead of strands of hair I'm getting see through hair. any suggestions?
wyrwulf posted Sat, 23 September 2000 at 10:09 PM
Are you having the problem before or after rendering? Before rendering the trans looks quite odd. It is "see through" with dots. After rendering it looks good.
Brooke posted Sat, 23 September 2000 at 10:54 PM
after rendering. instead of being lifelike and wirey it's hollow and see through
lalverson posted Sat, 23 September 2000 at 11:55 PM
It sounds like the texture map isn't loaded or the trans map isn't loaded by the way you are describing it.
bloodsong posted Sun, 24 September 2000 at 10:37 AM
heyas; you meant set transparency max to 100% and min to 0%, right?
