darian_0 opened this issue on Sep 24, 2000 ยท 2 posts
darian_0 posted Sun, 24 September 2000 at 11:40 AM
Jaager posted Sun, 24 September 2000 at 1:17 PM
We are talking about different things here. The item that you are morphing is a character and not a prop. You can only apply a morph to a single obj. What you have there is either chest or collar - depending if it is Vicki or P4. You CAN take the whole mesh (or any combinationof parts) into a modeler as a single object and do as complicated a morph as you wish. But before you can use it in Poser, you must first stop off in Compose and break it out into the constituent elements - each being the morph for its root element. Once you have all the morphs applied to the figure, you can make a whole body morph to save a million clicks, but a body morph is not a morph, it is a text trick to set several dials by using only one. If you do not know how to set a whole body morph - ask here, I will tell you what I think is going on, so that you can figure out what to do. A prop is usually only one obj and there are some ugly location issues with the morphs.
