Blog opened this issue on Apr 05, 2004 ยท 10 posts
Blog posted Mon, 05 April 2004 at 5:54 AM
Quest posted Mon, 05 April 2004 at 7:05 AM
This is excellent work Blog, great detail here! Have you tried UVMapper Pro?
Blog posted Mon, 05 April 2004 at 7:10 AM
UV Mapper would be great but I am using TrueSpace 6 which won't allow me to save files as .obj; any other suggestions?
pogmahone posted Mon, 05 April 2004 at 9:19 AM
Attached Link: http://www.unwrap3d.com
Unwrap3d imports/exports a huge range of file-types My only crit of the spray bottle is that you need a hole or slit for the trigger to slide back alongbigbadelf posted Mon, 05 April 2004 at 10:40 AM
Pardon my french, but here goes: The trigger looks too insubstantial at that length to withstand the continual pressures on it. Is the screwtop glowing with too much ambience or is that just the way the light's reflecting off the ridges? The width of the body looks too narrow, especially with the depth of the concavity, which is presumably on both sides. The closer knife seems to be intersecting with the bottle on both ends... but you probably don't care about that right now, so, nevermind. Good luck with the top mesh. I get very frustrated with things like that. Looks very nice so far, Blog!
Blog posted Mon, 05 April 2004 at 12:47 PM
I am in the process of remodeling everything about the screwtop; including a mechanism for the trigger; I just wanted to post the rough mesh before I left to school. I will likely have the mesh completed by this evening. As for the narrowness I want it to look used and partially empty.
ddruckenmiller posted Mon, 05 April 2004 at 3:08 PM
But the weak trigger is realistic - I always bust them about halfway through the bottle... PS even if you didn't go the PR route it'd still be cool. Haven't seen too many spray bottles around - maybe we could make a chess set outta them!
bigbadelf posted Mon, 05 April 2004 at 4:30 PM
My bad then. LOL @ chess set.
ddruckenmiller posted Mon, 05 April 2004 at 6:05 PM
No, really! On a big 64 square Armstrong linoleum kitchen tile floor! I can see it now "Fantastik to Windex's Formula-409 3, Windex x Generic Brand.
bigbadelf posted Mon, 05 April 2004 at 6:47 PM
I love it.
