ominousplay opened this issue on Apr 10, 2004 ยท 5 posts
ominousplay posted Sat, 10 April 2004 at 3:09 PM
I am creating 1/2 of a model in vertex medeler, then duplicating with symetry, then linking the two, vertex by vertex. I tried welding and came out with a crease or ridge that I wouldn't seem to smooth. What do other people do for this? I've seen some great models in the Carrara Gallery. Also, I've got a question about models with clothing... If I model a human, the add clothe, how would I animate with a skeleton? Should it be one mesh, with the clothing and the human mesh as one? Last question: I'm just beginning to use Carrara's uveditor. I've used UVMapper for some time and I'd just like to know what people thought of the two.
Never Give Up!
ominousplay posted Sat, 10 April 2004 at 4:57 PM
A reply to myself, how lame is that? :) I played around and found if I duplicate one half of a model (symetric) and then sellect the two sides I'd like to join, then just LOFT... ugh. I don't know how many times I've linked each vert. I'm such a dork. I guess I like doing things the hard way. Rs.
Never Give Up!
yolkworm posted Sat, 10 April 2004 at 10:23 PM
I've used UVMapper Pro quite a bit and I think it's superior to Cararra's UV mapping tool. - Bill
keithw posted Sun, 11 April 2004 at 9:43 AM
For joining 2 halfs a use weld, loft, and link depending on the circumstance. I find that sometimes loft doesn't connect the 2 halfs correctly. I think that it might have to do with the order in which the points are selected. I have been going to test that but haven't found the time. I also have UVMapper Pro and agree with yolkworm. It is better. Keith
ayodejiosokoya posted Sun, 11 April 2004 at 3:24 PM
I use Ultimate Unwrap www.unwrap3d.com . It isreally good, although I think it could do with a few improvements. The free version (Lithunwrap) is quite good too http://files.seriouszone.com/download.php?fileid=198 . I opened the Carrara UV Mapper a few times and realised very quickly that it was not upto the task of mapping serious models. I rarely touch it. I think it is definately one of the things that needs a serious overhaul for version 4.
