Forum: Vue
Subject: Need some advice on camera placement.....
dlk30341 opened this issue on Apr 10, 2004 ยท 4 posts
dlk30341 posted Sat, 10 April 2004 at 7:16 PM
I'm trying to do a scene of a neighborhood. However, I just can't find the right place for camera to make the ground "eye" level. As soon as I think I have it, I start putting houses in place & they all look as though they are going downhill the closer they are to the camera. As I progress further back in placing the houses the appear to be gradually going up hill. Simply put in slope going from down to up. I've spent all day messing with us and have finally caved to ask for some assistance. Any advice would be greatly appreciated. TIA - Debby
sittingblue posted Sun, 11 April 2004 at 12:31 AM
Debby, can you post a quick render? That would help immensely in understanding your dilemma.
When I position my camera, I try to use a photographer's mind-set. Of couse, photography is an art and a science, hence, it is a long-term study for me.
Charles
Charles
erka posted Sun, 11 April 2004 at 5:16 AM
Debby, are you using a wide focal angle (less than 30)? Such values distort the perspective, resulting in a "fish eye" look. This is obviously very apparent on things that should be strait, like houses and walls. If you want to encompass a wide range in you picture, my advice is to use the usual architectural rendering trick: Use a "normal" lens angle (like 36), move your camera far enough to see everything you want. Now you'll probably have unwanted "empty" areas around. Just render a larger resolution than you need, and crop the unwanted parts in a paint program....
dlk30341 posted Mon, 12 April 2004 at 9:45 AM
Thanks for the advice..will give it a whirl. Sorry for not getting to you all..was busy all day yesterday.
