Angelouscuitry opened this issue on Apr 12, 2004 ยท 11 posts
Angelouscuitry posted Mon, 12 April 2004 at 3:08 PM
I've DL'd global illumination file from the free stuff area at 3Dcommune(I had'nt found the one in here yet.) It opens and imports as a whole bunch of sphereical lights grouped together, but they do'nt emit light as is, and need to be adjusted. How are all of the lights intended to be adjusted together as a group?
Angelouscuitry posted Mon, 12 April 2004 at 3:12 PM
Angelouscuitry posted Mon, 12 April 2004 at 3:26 PM
Attached Link: http://www.renderosity.com/freestuff.ez?Form.Contrib=Beanzvision&Topsectionid=0
I think, actually, the glbal illumination file here is the same as 3Dcommune's, as the donor's name there is Beanz, and Beanzvision here... BTW - the URL for the file, here, is attached...Angelouscuitry posted Mon, 12 April 2004 at 3:34 PM
Angelouscuitry posted Mon, 12 April 2004 at 3:37 PM
Erlik posted Mon, 12 April 2004 at 4:33 PM
Just go down below the main screen and click on radial lights and choose Select All of Type. You can edit them as you wish then. BTW, are you certain those are lights that you downloaded? Are they spheres that have to be turned into radial lights? Select the group, ungroup it, go to Edit menu and turn selection into radial lights, group back again. Also, I couldn't find either Beanz or Beanzvision in Bryce Free Stuff at 3D Commune. BTW 2, Shadow Toggle button will just turn on and off the shadow on the ground plane in wire preview.
-- erlik
ascript posted Mon, 12 April 2004 at 5:21 PM
If you want the shadows off on the lights, you do that in the edit thing (for the lights). You can also turn sun/moon shadows off in the sky lab. I'd select all lights, ungroup them and then set them to a very small number. If they are set to linear they may not light far enough away to light your figure, depending on how big the scene is. Try changing it to falloff none or try some ranged settings.
diolma posted Mon, 12 April 2004 at 5:26 PM
. (Dio Bookmark)
Beanzvision posted Mon, 12 April 2004 at 7:53 PM
Attached Link: http://www.renderosity.com/gallery.ez?ByArtist=Y&Artist=Beanzvision
Hello it's me!!! Select the group, un group and hit 'E'. This will take you into the light lab, there you can change the lights intensity and shadows. It's just a matter of getting used to using it....Some examples can be found in my gallery!pauljs75 posted Tue, 13 April 2004 at 3:53 PM
Dukduk also has a pretty good GI rig (lotsa lights, 160?) for Bryce somewhere in freestuff here at Renderosity. The trick to using it was to set the light output to a low value (1 or 2, since you're using a crazy amount of lights) and then adjust the actual brightness by setting the light color. Not sure if you need to turn off shadows overall, but disabling cast shadows on some lights might help.
Angelouscuitry posted Wed, 14 April 2004 at 12:37 PM
