Forum: Vue
Subject: Problem with volumetric lights and alpha planes
lilzeek opened this issue on Apr 13, 2004 ยท 5 posts
lilzeek posted Tue, 13 April 2004 at 4:24 PM
I am having problems with volumetric lights and my waterfall alpha planes. You can see in the picture that there is a line, the edge of the plane, that is visible when I use volumetrics. It disappears as I turn down the quality of the light. I have tried adjusting many settings in the transparency tab as well as the transparency function but cannot get it to disappear. Help will be rewarded.
firebolt posted Wed, 14 April 2004 at 4:29 AM
Hi, I know the problem you describe, but also do not have a solution. Only recently, there was a similar question in the forum that went unsolved. I'd really be grateful for any hints how to correct this. So, should you ever find a way, please post it :-)
gebe posted Wed, 14 April 2004 at 4:34 AM
We all know this problem. Two solutions: 1. play around with the light and the cam 2. don't use alpha planes with volumetric atmospheres.
rodluc2001 posted Wed, 14 April 2004 at 4:34 AM
you can only use NON- volumetric light near the alpha plane...
lilzeek posted Wed, 14 April 2004 at 5:45 AM
Ok thanks, I have been putting off releasing my waterfalls due to this problem but since it seems inevitable for now I will get on with things.
