Forum: Poser Technical
Subject: Need women's clothing with breast morphs
divingbuddah opened this issue on Sep 29, 2000 ยท 4 posts
divingbuddah posted Fri, 29 September 2000 at 9:56 AM
I need athletic clothing (T-shirt, leotard, sports bra) that conforms and has the same breast morphs as the Poser4 and Victoria models. Where can a get these? What software would I need to make them myself? Painting on texture maps does work well enough (nipples, butt cracks) and I want to amimate so render touch ups are too tedious.
Kevin posted Fri, 29 September 2000 at 10:06 AM
Magnets. It was the easiest solution I found. You put the clothes on, morph the figure, and the use the magnets on the clothes to make them look right. Then export and import as morph.
dwilmes posted Tue, 03 October 2000 at 9:42 PM
Put the morphs on the clothing only, then use Conforming Morph controls, so the clothing will automatically adjust to any figure. Then you don't have to re-do it every time you want to use the teeshirt etc on another figure. Nerd has a Conforming Halter Top in the free stuff, for a starter. Doing the morphs is the hard part, making them CM is just a couple of mouse clicks. Dan http://www.neca.com/~dwilmes/cr2edit.html
Rob_Sterling posted Fri, 13 October 2000 at 11:00 PM
Not sure what a "conforming morph control" is. Could you explain further, dwilmes?
