Drezz opened this issue on Apr 15, 2004 ยท 10 posts
Drezz posted Thu, 15 April 2004 at 1:17 AM
hey does anybody know where i can find a morph for victoria 3 that will move only one eye up or dwn, right or left, instead of both? im tryin to create a friend and one of her eyes is a little higher than the other, so im kind of at a loss unless somebody can help...
Little_Dragon posted Thu, 15 April 2004 at 3:30 AM
Do you have Poser 5? If so, you can use the Split Morph function to divide a morph into separate left and right sides.
Dave8 posted Thu, 15 April 2004 at 4:14 AM
or u could just click on the eye u want to move and use the dials
hauksdottir posted Thu, 15 April 2004 at 4:52 AM
...but it isn't just moving an eyeball. You have to move the lids as well. Morphs usually have associated PBMs so that things will move together. Carolly
Momcat posted Thu, 15 April 2004 at 6:29 AM
Split morph? How do you do that? I've never seen that function.
ockham posted Thu, 15 April 2004 at 9:57 AM
Applying a Wave to the head will do the job quite easily. As soon as the Wave appears, you'll see one eye socket is higher than the other; you can then adjust the amplitude, phase and offset until it's right.
Little_Dragon posted Thu, 15 April 2004 at 5:42 PM
Click on the little arrow to the right of a morph, and you'll see a list of options (reset, delete, split, etc.).
Momcat posted Thu, 15 April 2004 at 6:21 PM
Well now! Thank you so much for pointing that out. That's going to
make a lot of things much much easier. >^_^
hauksdottir posted Thu, 15 April 2004 at 8:38 PM
The new morphs will appear down at the bottom of the dials. I need to see if that works for things like making a chin a bit longer on one side. A quirked eyebrow or lop-sided dimple help to add character to a face. Carolly
Drezz posted Fri, 16 April 2004 at 2:00 AM
That is the sweetest thing ive learned so far. Thanks a million. That will help a ton on some of my stuff.
