Subject: Prop motion save?
Torulf opened this issue on Apr 18, 2004 ยท 8 posts
Torulf posted Sun, 18 April 2004 at 5:20 PM
Are there any ways to save motions for props like the animated poses?
TG
Little_Dragon posted Sun, 18 April 2004 at 6:40 PM
Yes, but the prop must be parented to a figure, both when you save the pose and when you apply it.
xantor posted Sun, 18 April 2004 at 7:14 PM
That is strange, they could have made props have there own animation settings too. Even bryce can do that.
texmextortilla posted Sun, 18 April 2004 at 8:09 PM
well, this isn't bryce now is it?
xantor posted Sun, 18 April 2004 at 11:01 PM
No it is better than bryce :)
xantor posted Sun, 18 April 2004 at 11:03 PM
If bryce had real animation in it, it could be a great program, but as it is, it isn`t so good.
lesbentley posted Mon, 19 April 2004 at 4:22 PM
Parent the prop to a figure, create the animation, save the pose using "Select subset" to include only the prop. If you want to be able to apply the pose to the prop without parenting the prop to a figure: Open the pz2 in a text editor and replace the word "prop" with "actor". You will still need a figure loaded in the document in order to apply the pose, but the prop does not need to be parented to the figure.
Torulf posted Mon, 19 April 2004 at 8:54 PM
I have solved the problem. Open the set-up room and turn the prop to a figure. The morphs were not destroyed. Its work perfectly.
TG
