odeathoflife opened this issue on Apr 19, 2004 ยท 6 posts
odeathoflife posted Mon, 19 April 2004 at 1:50 PM
Hey folks, I am making an image in poser 5 firefly using the dazmil dragon ( well 2 actually ) one has the Daz Dragon texture, and the other has the free HR dragon textures ( the gold ones available in the free stuff) but the wings on either are not working, I used the mat poses available from both, and it makes the falloff 1.0 so I figured that was the problem, so moved it down to 0 still rendering hte membrains as black, so I removed the trans map altogether, still black, so removed the textures and just used the material colour, renders black....I havn't a clue what ta do now. Any one else exper. this? Got's a solution? thx muchly. death
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
who3d posted Mon, 19 April 2004 at 6:20 PM
Umm.. MilDragon worked fine for me last time I checked... is the problem really blatant or might I have overlooked it?
Crescent posted Mon, 19 April 2004 at 7:09 PM
Did you try setting the displacement to .001 or so in the render settings? That might fix it. Also, set the fall-off to 0, not 1. This will keep the fall-off all the way up, all the way through. I always set my fall-off to 0 for transparencies. Hope this helps.
Lyrra posted Mon, 19 April 2004 at 7:43 PM
check where the trans map is plugged in, some P4 made MATS get it in the wrong place. Likewise for bumps.
Artalgo posted Mon, 19 April 2004 at 11:42 PM
Make sure that "Remove backfacing polygons" is not checked in the render settings.
odeathoflife posted Tue, 20 April 2004 at 12:40 AM
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
