andygraph opened this issue on Apr 19, 2004 ยท 25 posts
andygraph posted Mon, 19 April 2004 at 5:42 PM
I have remove all lines as in tutorial: vn lines (Normals) vt lines (UV mapping lines) g lines (Grouping Data) usemtl lines (Material Data) mtlib lines (Material Library pointer lines) f lines (Face Data) and i have save only "v" lines but when i try to load my morph i read this message: Couldn't read the geometry file But if i delete all lines but don't delete the "v" lines AND "f" lines, the morph is ok .... ???!! where is my error ? thx for feedback ;-) Andygraph
chud posted Mon, 19 April 2004 at 7:58 PM
Make sure you have the correct body part selected,perhaps.
andygraph posted Tue, 20 April 2004 at 4:26 AM
yes i'm sure
andygraph posted Tue, 20 April 2004 at 4:34 AM
If i use the v lines AND the f lines my morph work ! but the tutorial don't say about the "f" lines.. i have try to import this obj with "v" and "f" lines and i can't import it, infact it work only as morph target ;-)
EnglishBob posted Tue, 20 April 2004 at 5:14 AM
I regularly use 'v' only OBJ files as morphs, and they have never failed to work yet... What model is your morph for? If I have it, I'll take a look at it for you if you want.
andygraph posted Tue, 20 April 2004 at 5:21 AM
my morph is for sale ;-) anyway i use victoria 1
EnglishBob posted Tue, 20 April 2004 at 5:24 AM
I have Victoria 1 also. If I look at your morph, I promise to delete it afterwards and not give it to anybody else. It depends if you trust me or not. I wouldn't. ;)
andygraph posted Tue, 20 April 2004 at 5:31 AM
i can create a another morph with default morphs of v1 because i have the same problem ;-) your e-mail ?
EnglishBob posted Tue, 20 April 2004 at 5:36 AM
I've sent you an IM.
EnglishBob posted Tue, 20 April 2004 at 5:59 AM
Got that. I ought to have said that I should be working, and don't have access to Poser until tonight (I'm on GMT+1). However I successfully opened both OBJ files in Anim8or - test1 is just a cloud of vertices of course, but test2 looks like an actual head. On comparing the files, their v lines are identical as far as I can tell. Assuming you don't get a 'wrong number of vertices' error, it /should/ work... What procedure are you using to apply the morph?
andygraph posted Tue, 20 April 2004 at 6:13 AM
select the head and upload the morph ....simple
EnglishBob posted Tue, 20 April 2004 at 6:19 AM
Simple, yes, but only if it works... :-) When I get home, I'll try your morph and report back. If it works for me, I'll prepare another morph in the same way and see if it will work for you. Hopefully we can locate the problem that way.
andygraph posted Tue, 20 April 2004 at 8:17 AM
many thx EB ;-)
EnglishBob posted Tue, 20 April 2004 at 3:05 PM
Andygraph's morphs worked for me, whether with v and f lines or with just v. The morph I sent back to him had v lines only, and worked for me obviously, but not for him. He's on a Mac. Any ideas?
EnglishBob posted Wed, 21 April 2004 at 3:56 AM
Boy, is that helpful. Not. And the chances of CL going back to an old version of Poser to fix any bugs is minuscule. They can't even debug Poser 5. It beats me how they can break a feature like that, but it's not the first time that code that was fixed in one version became un-fixed in the next. :-( That seriously reduces our options for distributing morphs, since an OBJ with facet information left in will be in breach of copyright. The vertex-only form is generally accepted as being safe to distribute, since it's too much trouble to join all the dots together and make your own Vicki. :-) Maybe this explains why I've seen people sharing morphs as a CR2 'carrier', with which you have to use Morph Manager to copy the deltas into your own character CR2. Where did you find out about this, by the way?
andygraph posted Wed, 21 April 2004 at 4:01 AM
this is a problem if you want sell MT for V1/2 to mac user without use "big" CR2 :-(
andygraph posted Wed, 21 April 2004 at 4:02 AM
poser 5 for mac have the same problem anyway
EnglishBob posted Wed, 21 April 2004 at 4:19 AM
Just though of a possible workaround - what if you put in a single fake 'f' line? Try adding this after the 'v' lines: f 1/1 2/2 3/3 4/4 This might be enough to satisfy Poser that the file is genuine, but it won't harm the copyright situation.
andygraph posted Wed, 21 April 2004 at 7:30 AM
only this line f 1/1 2/2 3/3 4/4 ???
EnglishBob posted Wed, 21 April 2004 at 7:35 AM
Yeah. I'm supposing that Poser looks for 'f' lines when it opens an OBJ, to check whether it's valid or not. But there's nothing in the OBJ specification to say how many facets there are: one is a perfectly valid number. I'm hoping it will be enough to fool Poser's format checking routine.
andygraph posted Wed, 21 April 2004 at 11:23 AM
WOW it's work on mac now !!! ** Tutorial Morph Squishing 102 for macintosh ** as Morph Squishing 102 tutorial BUT .. for mac user is need add this special line "f" to end of "v" lines example: v -0.00827163 0.635433 0.041891 v -0.00820857 0.63581 0.0426039 v -0.0121407 0.635551 0.0394929 f 1/1 2/2 3/3 4/4 many thx EnglishBob for have fix this problem :-D
EnglishBob posted Wed, 21 April 2004 at 11:30 AM
That's good news. :-)
Traveler posted Wed, 21 April 2004 at 12:07 PM
Excellent work!
geminiron posted Wed, 28 April 2004 at 8:24 PM
after all this time, how simple. Many thanks, both of you.
EnglishBob posted Tue, 25 January 2005 at 4:48 PM
Update (courtesy MarianneR): Squished morphs now work in the updated version of Poser5 (5.04) on the Mac.
