Subject: Picnic--This is What I get
Dreamspinner opened this issue on Oct 01, 2000 ยท 13 posts
Dreamspinner posted Sun, 01 October 2000 at 8:27 PM
I used the Soften Hip dial at 1.600. Solved the break thru at the hip and stomach area but the shoulders still stick out. This figure is one called VikkiMap or something similar. Liz Pope
Ghostofmacbeth posted Sun, 01 October 2000 at 9:37 PM
That is what I get without the update on Vicki ... With the update I only have to soften about 1 (maybe even less) and do the no nipple morph ... That is with either the vickie map 1 or the no map .. didn't try the other one ... It was simply a question of updates ...Got so dang confusing for a while
MDibble posted Sun, 01 October 2000 at 11:11 PM
While I don't have Vickie (frowny face), what I usually do is make all body parts covered by the conforming clothes invisible with the Hierarchy Editor. :/ Or am I missing the point? Mike
Dreamspinner posted Sun, 01 October 2000 at 11:18 PM
Normally I'd do that, but if you're going to apply a transmap to the catsuit, then you want some body part to be visible through the holes. I made a transmap with a large hole cut out over the stomach area. So you want that part to show through but you don't want the body ripping through in that area. Liz Pope Dreamspinner Inc.
rjghise posted Mon, 02 October 2000 at 1:44 AM
There is a corrected version of the catsuit at Fairywoods - I haven't tried it yet though to see if it works.
picnic posted Mon, 02 October 2000 at 7:54 AM
I think you need to find the Vickimap 2 version. Liz--do you have 2 texture maps for Vicki?? They issued a second version with a different map--that's the one Ghost and I are using, I'm sure.
Ghostofmacbeth posted Mon, 02 October 2000 at 8:59 AM
Actually picnic I am just using the first map ... Second version and all but first map. But there doesn't seem to be any problems.
picnic posted Mon, 02 October 2000 at 9:34 AM
Oh, that was misleading of me. I didn't mean she has to use the second map because I use both (actually I don't use either now--I'm using other maps--both some I've adapted from P4 and Cindy's), just that mine is called Vickimap2 I believe. I think I deleted the nomap 2 and left the map one on, but actually use my 'white' vs. 2. Hope this clears THIS up LOL. Yes, I remember that was very confusing. Melanie had all the versions on and couldn't figure out which to use, as I remember.
eallen posted Mon, 02 October 2000 at 2:56 PM
Hello, This is Eric at Zygote. We are unable to duplicate this problem. We do feel that this problem is due to the version of Victoria you are using. You will recall that we released a .cr2 update of Victoria after her initial release where the actual .cr2 is named 'Vicki.cr2'. The center points in her shoulders are slightly diferent in this version. I suspect this to be the cause of your problem. Make sure your model is called Vicky instead of Victoria. Feel free to email us at tech@zygote.com if you have any other questions. Eric Allen Zygote Media Group
Dreamspinner posted Mon, 02 October 2000 at 5:00 PM
I will check that out but I believe that I'm using that updated version. Thank you! Liz Pope Dreamspinner Inc.
Dreamspinner posted Mon, 02 October 2000 at 7:31 PM
I just checked and no I do not have that version of Vickie. Liz Pope Dreamspinner Inc.
picnic posted Mon, 02 October 2000 at 10:04 PM
Whew!! I would hate that you would still have that problem when we aren't G. Now you can go ahead, get that update and get on with your transmaps for her wild outfits LOL.
Dreamspinner posted Mon, 02 October 2000 at 10:35 PM
Would be nice. I sent an e-mail to Zygote about getting that cr2 file, but I haven't heard back from them. So you've seen some of my outfits? Yeah, I like them wild. The Catsuit is my favorite peice, then the Leotard, then the Unitard. Liz Pope Dreamspinner Inc.
