pararehabpro opened this issue on Apr 20, 2004 ยท 4 posts
pararehabpro posted Tue, 20 April 2004 at 12:18 PM
Greetings folks...here's my situation: I've got a beer can with legs, arms, hands, feet. I've attached the Edgar bones and they're attached. I've applied a walk path... I've designed the walk I want...now Presto! I apply it and set all the final ponts...look ahead, blah blah...hit okay....and nothing happens. Nothing...zip...I can hit okay until my finger falls off. NOTHING HEAPPENS!!!!!!!!!!!Arrggh! anyway, any ideas? thanks fred ( the guy with the shortened finger).
ockham posted Tue, 20 April 2004 at 12:57 PM
One possibility: Does your beer-man have the standard Internal names for his parts? As seen in a typical CR2: actor abdomen:1 <---- Internal name { name Abdomen <---- External name When a pose does nothing, it often means that Poser found no matching internal names. Another possibility: Are the parts arranged in a standard hierarchy, or does the figure skip some of the usual parts?
xantor posted Tue, 20 April 2004 at 12:57 PM
I would check that the figure you made works properly. Then you should check the body part names ( the internal names ) like hip and rForeArm they all need to be the right names with the proper case so rforearm is wrong and rForeArm is right. The body part names have to be right to use the walk designer.
xantor posted Tue, 20 April 2004 at 1:11 PM
Cross posted with ockham, our answers must have been seconds apart :)
