Subject: Broken 3ds imports
shogakusha opened this issue on Apr 22, 2004 ยท 8 posts
shogakusha posted Thu, 22 April 2004 at 10:22 AM
Can anyone tell me why 3ds files seem to break up the model when I import them into Poser? For example, i cannot accurately import the beautiful models from SciFi3D because they tend to be either 3ds (which breaks up) or MAX which Poser cannot handle. Thanks!
neilp posted Thu, 22 April 2004 at 10:45 AM
I had this problem a while back. I think I solved it like this : 1. Open the 3ds model in 3dstudio max. 2. Select each texture in turn (Material Window) and make the textures double sided. 3. save the 3ds model and re-import into poser. I'm not at my PC at the moment so I can't test that, but give it a try.
Tyger_purr posted Thu, 22 April 2004 at 12:03 PM
but what if you dont have 3dstudio max?
My Homepage - Free stuff and Galleries
panko posted Thu, 22 April 2004 at 1:34 PM
I encountered the same problem and I definitely don't have 3dstudio max.... :)
"That's another fine mess you got me in to!" -- Oliver Hardy
maclean posted Thu, 22 April 2004 at 2:40 PM
Unusual. I've been modelling for 4 years in max and I import everything to poser as 3ds, then convert it to obj. I started doing this because I wasn't happy with the stability of the obj export from max. I've never had a problem with 3ds files at all. I'm sorry I can't offer a solution. It could be that some technique has been used that poser doesn't like (and that I've never used), but I can't imagine what it could be. mac
xantor posted Thu, 22 April 2004 at 5:52 PM
A program called deep exploration can fix this problem, it seems to be caused by max 4 and 5 having a newer version of the 3ds file format.
dlk30341 posted Thu, 22 April 2004 at 6:23 PM
I've had this same problem with vehicles I've downloaded from Planit3D...I bring in the 3ds file & the vehicle is flying all over the place :(. Does the same thing in Vue as well.....
randym77 posted Thu, 22 April 2004 at 7:31 PM
Attached Link: http://www.micromouse.ca/downloads.html
Download Accu-Trans. It's free for 30 days. After that, it's $20 on the honor system. It's like a poor man's PolyTrans - it will convert among many different 3D formats. Open your "bad" 3ds file in Accu-Trans, then save it as an OBJ. You should be able to import it into Poser then.
